Whats the default temperature that the radiator fan kicks in on these engines please?
On mine its 92.
thanks mate..
Aye, same on mine. 92/94.
hmm this replacement rad and fan pack i have fitted does not start its fan.. looks like I need to try and get my opcom up and running on my new laptop...
what PITA that was...
so my codes are:
Total number of fault codes: 5
P1525 - Throttle Control Malfunction
(65) - Not present
P1550 - Electronic Throttle Control Engine Stop
(3A) - Not present
P1481 - Fan Control 1 Circuit Malfunction
(06) - Present
P1482 - Fan Control 2 Circuit Malfunction
(06) - Present
P1483 - Fan Control 3 Circuit Malfunction
(06) - Present
time to do some reading, anybody got any leads on these...?
Mine also kicks in at 92.
To test the fan you can unplug the coolant temp sensor, the fan should then be always on (with ignition/engine on). If the fan doesn't come on check for power going to the fan.
fuse 35 in the engine fuse box was blown, fan now working...
Those are the best fixes, lol.
nice easy fix
