Results 1 to 3 of 3
Thread: MOT failed on vectra 1.9 need help
    Regular Member faizyan6000's Avatar
    May 2011
    high wycombe
    Vehicle : vectra 1.9 diesel
    Trim : life
    Mileage : 92000
    Default MOT failed on vectra 1.9 need help
    hi my vectra has failed its MOT i just need some help with two of the fail points
    1 offside front anti-roll bar has excessive play in a ball joint
    2 nearside inner front tie bar/rod has excessive play in a ball joint
    could anyone please tell me what parts i need to fix this
    thank you in advance
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    1 are they talking about the anti roll bar drop link? if so thats a easy fix and the part is about £15 from vx and autofactors
    2 sounds like the inner track rod end which is not so easy as you need a massive spanner to undo the nut but the part is £20-25 from vx or autofactors
    West
    Replace both front drop links & do the inner track rods too, my view is if your doing 1 side you may as well do the other, it will save having to revisit later
  1. The GSi failed her MOT :(
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2011, 13:38
  2. Vectra failed mot
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 17:26
  3. Vectra 2005 2.2 SRI Direct Interior Fan/Demistor failed
    By sanderstrog in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 20:35
  4. vectra 150 55 Plate Failed MOT
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2009, 13:46
  5. Vectra cat converter failed
    By starcopal in forum Engine & Drivetrain
    Last Post: 8th March 2008, 19:09
vectra c track rod end failure
