Thread: 3.0 cdti glow plug relay HELP!!
    Regular Member dshelton999's Avatar
    May 2011
    manchester
    Default 3.0 cdti glow plug relay HELP!!
    Hi all,
    Car & spanner light came on yesterday so drove to the local garage so they can try for a code read on it. Came up that glow plug relay is faulty. When ignition is turned the glow plug light goes out really quickly. Car still starts normally and drives without going into limp mode even though spanner&car light comes on.
    Was just wondering if anyone knew were the relay is locate?
    Kind regards
    Vectra c, 04, 3.0 cdti y30dt 79,000
    Jun 2011
    Elland
    Damn, this different version of TIS2000 I have is knackered - no wiring diagrams working
    From memory, I think it is located behind the front wheel: you will have to take some of the bits of plastic off to get at it. What I can't remember is whether it's the driver or passenger side.
    If I get the wiring diagrams working, I'll get back with more info, unless someone else knows!
    Jun 2011
    Elland
    OK, diagrams re-installed
    It's not giving me the location of the glow time control unit for your model. But if it's any use, on mine, the unit is located IN FRONT of the DRIVER'S SIDE front wheel - there looks to be a panel if you imagine a line projected forwards at the height of the top of the brake disc. I have checked for mine, which is a 55plate sig V6 diesel, so this may be helpful to you... it may not, but it's the best I can come up with
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I had the same issue on my old 3ltr. Turned out one of the glow plugs was faulty but only at a certain temperature
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Alot of 3ltr issues popping up at the moment
    May 2011
    manchester
    Nice 1 for your reply, will have a look when I get in from work and get back to you.
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sorry to dig up an old thread guys but I'm having dramas with my glow relay got a p0382 code.
    Has any body got a picture of were it's located?
    Also does anybody know what resistance a should get at each glow plug? Trying to do all checks before actually removing them an putting a jump lead on them
    Car is a 2004 v6 Cdti veccy hatchback
    Quote Originally Posted by nutron View Post
    Not sure about that, think it is more to do with the dealerships scratching their heads and not being able to diagnose what in effect turn out to be are fairly basic and simple issues
    Many of them seem to be difficult to diagnose, until complete failure (such as the blocked SCV)
    We've already seen some members post for several weeks with symptoms but still not resolve, which cannot be diagnosed until the part has failed completely
    As above, erratic issues eventually turn into permanent issues and only then is it worth having it looked at
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Its located next to the power steering pump in front of drivers wheel behind bumper>>
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by alanv6 View Post
    Cheers mate.
    Will have a look tomorrow. Fingers cd it's the relay at fault and not glow plugs themselves
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. V6 Cdti glow plug relay
    By Critch in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 16:31
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
vectra c glow plug fault
vectra c glow plug relay
vectra c 3l glow plug relay location
opel signum 3.0 cdti glow plug relay
vauxhall 3.0 glow plug relay
vectra c 3.0 cdti light with spanner fault code glowplugs
glow plug control module signum 3.0 location
vauxhall signum 3.0 dti glow plug module
open z30dt glow plug unit
vauxhall vectra glow plug relay location
glow plug relay vectra c
where is a glow plug relay 30 l v6 vectra
vectra c glow plug module location
vauxhall vectra c cdti heater plug relay
https:www.vectra-c.comforumshowthread.php144946-3-0-cdti-glow-plug-relay-HELP!!
cdti glow plug control module wiring
vauxhall glow plug relay fault
vectra glow plug faults
2008 vauxhall vectra glow plug relay location
corsa c glow plug control module location
signum glow plug relay location
