Results 1 to 10 of 15
Thread: Debate and extra earth .
    north east
    Default Debate and extra earth .
    Evening all,
    Just thought Id chuck this infor a bit or investigation / conversation
    The Mrs `s Corsa is suffering a engine - body earth problem somewhere.
    Anyway my thought is to just run a new earth from the engine to the body, this then got me thinking, after getting a new alternator on my Vec this year and the amount that seem to fail. Would it be worth running an extra earth on the vec as well ?
    I have noticed on the suspention part of the front Strut thiere is a spare bolt that looks ideal for this job.
    Anyone done this / want to advise against this idea ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I don't think alternators fail due to lack of earth? They fail as they're not upto the demand - hence the CDTI has an uprated one.
    Personally I don't see the point.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Thought it was the clutches inside the alternator that was failing?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by CritchvxD View Post
    Then it's anyones guess? somesaid to me it was the diodes in the rectifier that popped prematurely. If the general over demands of the power steering pump didn't kill them first.
    Jul 2011
    edinburgh
    can`t harm taking off all the earths and cleaning them up and the body contacts and regreasing and run a new one or two at the same time i suppose,i bought a load of new earth cables to redo my cavalier turbo when i clean all mine up,once i get into it,thing`s battery went flat and is delocked.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Gazza4 View Post
    It probably is that. ****** cars an crappy faults that cost an arm an a leg to fix lol.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    True.
    north east
    Ok well, had another look tonight.
    drivers side suspention top tower has a spare nut that looks just like the standered earth points around the car.
    The engine lift out Hook at the back drivers side has a threaded stud on it, so in the ineterst of science and to me these 2 points are screaming to be connected I plan to join them and see what happens :-)
    north east
    Well the extra earth has been installed tonight ... will run it for a week then post a pic of it and any findings, so far start up and shut down are a lot less violent than they used to be.
    what is shocking is its almost as if vauxhall had planned for this but forgot to install it.
    Drivers side suspention top is a empty earth point, on the side of the brake fluid reservoir is 2 plastic clips that fit the cable perfectly and on the rear drivers side engine lift out mount is a threaded stud that takes a m5 nut. Earth cable cost £5 from halfords.
    north east
    How 2 submitted.
    Car starts easier, idles smoother and shuts down with out the violent finish. Head lights seem brighter and radio reception clearer.
  1. It's nearly time for....... the Winter Tyres debate!!
    By TonyP2020 in forum Handling & Braking
    Last Post: 21st January 2013, 23:06
  2. The answer to the great debate about
    By Ben50n in forum Comedy & Humour
    Last Post: 10th March 2012, 16:03
  3. The Winter Tyres debate room...
    By luke4487 in forum Handling & Braking
    Last Post: 20th December 2010, 09:49
  4. Estate Debate
    By Humph Backbridge in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 22:03
  5. Eastenders Debate
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 2nd June 2008, 21:42
