Thread: Sump bolt 2.2 DTi. Doing Oil change.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Default Sump bolt 2.2 DTi. Doing Oil change.
    Can anybody help me with a couple of questions as I'm changing my oil and filter at the weekend?
    1. Size of sump bolt. Is it recessed requiring a socket or will an adjustable spanner do the job?
    2. Is the sump bolt accessable without removing the plastic engine undertray?
    I'm using Valvoline SynPower fully sunthetic 5W-40 oil. I've used this on my cars in the past and have had no problems. Its certified for VAG/BMW/Merc and Opel longlife service intervals so the 10k miles I do between changes should be no problem.
    Thanks.
    Ross.
    stockton
    hi,
    i beleive its a torx t40 bit for sump plug (sump plug has a rubber 'o' ring unlike the usual brass washer too)
    the undertray needs to come off too cheers 690lee1
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Nice info but i think he'd of done it by now, date on that post was 24th October 2006! hee hee
    Quote Originally Posted by 690lee1 View Post
    hi,
    I've done it (a couple of times ) now but thanks for taking the time to post a reply.
    Regular Member eaglepva's Avatar
    Up North
    Hi mate, did you have to remove the undertray to change the oil?
    If I remember correctly, I did remove the undertray. I haven't owned that car for about 2 and a half years so it's a struggle to remember.
  1. Replies: 9
    Last Post: 10th September 2012, 17:04
  2. Sump Plug - Oil Change
    By Sparky67 in forum Engine & Drivetrain
    Last Post: 25th March 2010, 21:43
  3. Sump Plug Bolt Advice
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 19:36
  4. Sump Drain Bolt
    By Dazzar in forum Engine & Drivetrain
    Last Post: 4th January 2007, 09:51
  5. Sump bolt 2.2 DTi. Doing Oil change.
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2006, 12:09
opel 2.2 dti oil bolt
