Thread: rattling from rear end over bumps
    Worksop
    Default rattling from rear end over bumps
    what could caue this? and no its not dump valve
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Brake pads rattling in the carrier/caliper......I had it for months and the day it was booked in to have new cat and back boxes I found the answer on this forum. 1hour later new pads and discs and no rattle. Cheap pads dont fit correctly so go to vx for them.
    Best way to find out is drive down a bumpy road so the rattle is kinda constant and lift the handbrake a few notch's if it stops its the pads.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    My guess is the boot. I checked everything.
    Adjusted the boot strike bar. An hey presto no squeek
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Rear pads
    Worksop
    garage ave just put new vx pads in
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    Rear upper control arms. It is a classic Vectra C problem. The rubber bushes wear and they rattle. I did mine 18 months ago. It only took me 3-4 hours and I am a Vectra novice, working alone. I replaced the whole arms. I got a pair or rear UCAs from a well-known online auction site for less than £30 or so - delivered.
    And it worked! My rear tyre wear was improved dramatically too.
    Be sure to get your wheel alignment checked and corrected after any suspension work.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member pistonpete's Avatar
    May 2011
    chester
    Now are ya sure its not that dump valve tomo?!?!?!? Lmao
    Worksop
    Quote Originally Posted by pistonpete View Post
    no thats whistling under boost
    Regular Member Jezzy's Avatar
    S.E
    Here's the cause of the rattling from the rear end:
    http://www.vectra-c.com/forum/showthread.php?t=144471
    Worksop
    its coming from low rear jezzy sounds like somat is loose not spoiler
    tho tried that one
  1. Rattling from Rear
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2010, 20:29
  2. rattling at rear
    By evil.c65 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2010, 09:07
  3. Rattling rear hub
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 16:06
  4. Knocking from Rear - When over bumps & un-even roads
    By breeza in forum Bodywork & Interior
    Last Post: 28th December 2007, 00:16
  5. Crunching sound at rear over bumps?
    Last Post: 19th December 2006, 16:57
vectra c rattle over bumps
vectra c rattle coming from back on bumps
2005 vectra back rear knocking over bumps
vectra c rattle from rear
vauxhall vectra c rear rattle
renault scenic rear end rattle
vauxhall vectra rattle from rear
vectra rear control arm rattle
rattle from rear over bumps vectra c
rattling from rear suspension vectra c
rear brake rattle over bumps vectra
vectra c rear end rattling
vectra c noise engine bumps
