Results 1 to 2 of 2
Thread: Bg44k
    Aug 2011
    denny
    Default Bg44k
    Does this cleaner go into the petrol tank and what valves will it clean would it clean the egr valve what is the difference between this stuff and say redex cheers
    ijk571
    Guest
    see www.powerenhancer.co.uk. Its much stronger and better than redex. I've used in My old Mondeo and my Vec SRI and it works! If yours is diesel you'd need the BG244K instead. Ive used both with no problems. Yep, into a full tank of fuel, run to 1/4 full and fill up again. Run this through and then when low fill up as normal. It's best to let it last as long as possible in the tank (couple of weeks or so), not try to use it all up straight away
  1. BG44K petrol system cleaner.
    By disco dan in forum Engine & Drivetrain
    Last Post: 9th April 2013, 14:38
