Thread: Air Con Condensor
    Regular Member iain.condliffe's Avatar
    Feb 2007
    Cheshire
    Default Air Con Condensor
    Got to have mine replaced, tiny hole, but a hole none the less!
    Does anyone know if the condensor for a CDTi 120 has the drier attached or not?
    Searched everywhere and cant find a definitive answer!
    Thanks in advance!
    Aug 2010
    Leeds
    Why not repair it as it's only a mini radiator so it can be soldered if your unable to do this a radiator specialist can and save you a few quid.
    Feb 2007
    Cheshire
    Cant really afford to have the front of the car off for long, although didnt even realise it was an option!
    The actual units arent much and the lad who is doing it is very good and charging minimum labour.
    Plus were about to drive to france so I dont want it going pop...
    Regular Member Keif's Avatar
    In the Garage
    When you say "drier" I take it you mean the fan.
    Normally when you buy a new replacement Air Con condenser, it is just that. Just the condenser, you have to swap the cooling fan over from your old one.
    I've done a few (not on a Vectra tho)
    Feb 2007
    Cheshire
    Its like a metal cylinder with what has been described as a big lump of silics gel in.
    Without drier - http://www.autoairconparts.co.uk/Car...-16-6514A.html
    With drier - http://www.autoairconparts.co.uk/Car...t-16-6514.html
    And sadly I cant see in to check it (and the part number on the label doesnt match with anything!!)
    Engine : 1.9 CDTi
    Have you looked in the guides section as I think it shows you in there.
    Feb 2007
    Cheshire
    I think it only refers to a 150 but shall read it again.
    Engine : 1.9 CDTi
    Pretty sure its the same
    11 Post(s)
    Quote Originally Posted by Bigtee View Post
    It's made from monkey metal. Plus it's aluminium, so it'll need tig welding, but as it's so thin, you'll probably just blow more holes in it.
    Also, as the system is under high pressure, I doubt you'd get a proper seal.
    Soldering went out the window when they stopped making radiators out of copper.
    In the Garage
    Apologies Iain, of course the drier. When I replaced the Air Con condenser on my Astra, I had to swap everything over including the fan and drier.
  1. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  2. Air con condensor fubar
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 10:34
  3. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  4. Air-con condensor..
    By tonyo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 21:28
  5. Air Con Condensor Help!!
    By Jimooo in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 22:34
