Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Timing chain kit please help!
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Default Timing chain kit please help!
    Ordered my timing chain kit the other day and picked it up today.
    Had a look through the box and i'm not convinced its the right one
    The tentioner has no release pin but has a small hole (not sure if this is because its controlled by oil pressure or spring loaded) All the guides i have read for the 2.2 direct engine show a tentioner with a release pin.
    Also the Chain sprockets have no int or ext marks like the ones shown in various guides, is this a problem?
    Wouldn't surprise me if its the wrong kit as the blokes in part department near me arn't the cleverest and this wont be the first time they've got something wrong
    If anyone can advise before i strip my car down and fine out its the wrong kit, its for the Z20NET
    Regular Member Jezzy's Avatar
    S.E
    What's the part number for what you bought? Oh, and don't rely fully on 2.2 reference material, you'll never know where it's leading you astray from what you need to do on a Z20NET. You should buy the Haynes manual for the Saab 9-3, as it covers your engine.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I'm sure thats the NET tensioner as it has the extra oil hole. You activate it by pressing a pry bar on it when its fitted. I think its only the balancer chain that has the pin. Pop onto the 2.2 forum mate as the new 2.2 kits now have the NET tensioner so they'll be able to give you the correct information.
    EDIT: Vocky recommends activating it before fitting LINKY and LINKY.
    EDIT# 2: Yep that is the NET tensioner and it has no realise pin.
    Oct 2010
    middlesbrough
    Cheers fellas, checked on genuinepartssearch and it's the right kit, so the z20net kit is different to the z22se in some aspects.
    Pressed the tentioner in earlier as I wondered why it wasn't spring loaded, only to activate it by accident! Doh! Apparently it dosen't really matter as some recommend activating it before and some say once installed.
    Getting a Haynes manual when I get chance but will be using guide on z22se and my dads experience when we attempt this on saturday.....wish me luck
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    I have the same set up in the garage waiting to get fitted and it looks identical to the one on show ,,,mine is for the Z20 NET
    Vehicle : SRi
    Mileage : 137000
    Good luck mate, its not a job for the faint hearted.
    Edinburgh/outskirts
    Mileage : 38000
    Dont think i would attempt this kind of repair i took it to my local garage for them to have a look at and they said they have never done one before but will give it a try ....not on my motor you wont i said ,,,so it will be the old garage that done the tensioner b4 least they know what they are doing
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by signumboy View Post
    LOL, "we'll give it a try"
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    will be watching this one closely I have been considering doing it as well... A few ish questions though...
    Are you guys changing the chain as well? How much was the kit? have you got a kit part number you can share? What noises etc have prompted you to go for this?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Caveman_nige View Post
    There are better mechanical tensioners for tuned engines as well You should delete the balancer shaft while your at it, for a free 10-15 horses.
  1. Timing chain
    By dave_scarborough in forum Engine & Drivetrain
    Last Post: 27th April 2012, 22:30
  2. timing chain
    By barneyp06 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 11:04
  3. timing chain mod
    By cavysri16v in forum Engine & Drivetrain
    Last Post: 21st February 2010, 10:46
  4. Timing chain??
    By wazza007 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 10:02
  5. 2.2 timing chain
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2008, 15:54
