Thread: Running rich ?
    Regular Member tosh23's Avatar
    HULL
    Default Running rich ?
    vectra manual estate 1.9 cdti 120 (2007)
    Just a quick one..
    On tickover my computer says 0.2 mpg, but my wifes vectra 2.2 dti says 0.1 mpg..
    Am I running rich ?....Tosh
    lincolnshire
    Quote Originally Posted by tosh23 View Post
    Just a quick one..
    you'd be gettin more black smoke out the back than usual if you were/are
    Mileage : 000
    Is the air filter clean.
    north east
    clean air filter and MAP sensor, also check when the engine is warm although in this weather it should be reading 0.1 to be honest.
    If you had the aircon switched on in your car and off in your wifes car that would account for the higher reading that you saw. An engine will use slightly more fuel when the aircon is switched on.
    swansea
    But they're different engines aren't they, would have thought that the figures would be different.
    Plus they aren't exactly accurate. Just ignore it mate, every engine is different.
  1. Car's running RICH *HELP*
    By Mark Evison in forum Engine & Drivetrain
    Last Post: 7th August 2012, 22:22
  2. Help!! car running Rich low MPG Diagnostic report inside
    By tattootroy in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 02:08
  3. 2.2DTi running rich ?
    By Daywalker in forum Engine & Drivetrain
    Last Post: 19th September 2009, 13:25
