Thread: DPF problems on a 120hp. HELP!!!!!!!!!
    lemvig
    Default DPF problems on a 120hp. HELP!!!!!!!!!
    Id have a problem with my car and the people at Opel/Vauxhall cant find the solution.
    I did have alot of problems with it last year and Id get a completely new DPF, EGR and pressure valve and it did run without any problems until recently.
    the problem is that after a regen it will go on the lamp program and the yellow lights turn on the dashboard. This happens every time at 300-400km.
    it will be on the lamp program until 1200-1400km and the regen happens.
    after a regen the yellow light is of and the car runs perfect again and then after 300-400 it all starts over again.
    Vauxhall says that the pressure valve measures a too high pressure but the tech2 tester says that the DPF is only about 50% full ?!?!?!?!
    Vauxhall says that the pressure valve is ok and the pipe where the pressure valve is attach is not blocked. ?!?!
    Vauxhall dont know what to do and this is the 3. time they have it.
    the only thing that Vauxhall did is that they did take it out on a drive with the tech2 tester on the car until it did a regen and then after the regen they used the tester to "cheating" the car to think it did get a new pressure valve. Vauxhall did say that it then would find out how long it was in the DPF program but after 300-400km it start all over again ?!??!?!
    Vauxhall says that its out off the DPF program and that it only happens if the battery has been taken off within 5 min after the keys has turn off the engine. Because the control box must have 5 min. to store the information about how long there is to a new regen ?!!??!!?!!?
    please help... and no the car do not have a power chip
    sorry my english
    lincolnshire
    get it re-mapped and delete the DPF at the same time
    Jun 2011
    Elland
    As above
    It doesn't diagnose the problem, but cures it by removing the items causing the problem.
    Software DPF removal, replace the DPF with a piece of plain pipe, or take the DPF off, bash the insides out and re-fit.
    Whilst you are having this done, blank off the EGR and have it mapped out of the ECU. These things, coupled with a remap to 150hp, will have you thinking you have a new car!
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Is it a hatchback manual? I was lead to believe that the hatchback manual cars dont have a DPF?
    lemvig
    its a wagon. can Vauxhall do the above ?!
    lincolnshire
    Quote Originally Posted by N2B View Post
    find an independant to do the re-map dude
    Jun 2011
    South Shields
    Ah, a wagon. As above, a decent live mapper will be able to delete it for you.
  1. 2006 Vectra 1.9 CDTI 120hp Glow Plugs
    By Mark-Rainey in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 20:34
  2. engine FAN problems 1.9 (120hp)
    By vectrawhite in forum Vectra C / Signum Troubleshooting
    Last Post: 21st May 2012, 20:52
  3. 1.9CDTi 8v 120hp Cylinder Head Replacement
    By cphaza in forum Engine & Drivetrain
    Last Post: 30th December 2011, 02:31
  4. 1.9cdti 120hp REAL engine code?
    Last Post: 22nd November 2011, 15:51
