Results 1 to 10 of 29
Thread: Safegaurd
    Full Member
    Bristol
    Default Safegaurd
    Any one know about this took car to stealer said the no comunication with sonics, replaced sonics and it is saying the same. Anyone had this problem?
    What was the fault code?
    Full Member
    Bristol
    Hi big dave 2955
    B2955-06 - Anti Theft Warning System Sensor Datalink Circuit Low Voltage or Circuit Open
    B2955-0F - Anti Theft Warning System Sensor Datalink no Communication
    Taken from a quick google search - http://www.vectra-c.com/forum/archiv.../t-123387.html
    There is mention of a fuse being in the wrong place.
    Full Member
    Bristol
    Just looked at that and changed fuses still the same.
    Full Member
    Bristol
    I just rand stealer they are going to have another look tommorow night.
    Full Member
    Bristol
    Took to the dealers today, keeps comming up no comunication with ultrasonics. they say it a wiring fault. Where to start is the question, after changing all the fuses and the unit. The beginining is not the answer, I will be looking for Ha HA. .
    Jul 2009
    The Rift, Cardiff
    The sensors are connected to the roof loom, via a connection block on top of the interior light unit. The roof loom is a ribbon cable that runs down the c-pillar to the fuse box in the boot (rec). If you haven't already, check the fuses and ribbon cable connection in the rec and also check the connection on top of the courtesy lights.
    Full Member
    Bristol
    Ok I will have look at that tommorow. When I puchared the car the previous owner fitted a rear passenger roof light which I thought was standard on an SRi , all other sri have them fitted. This a 56 2007 model sri. He said the safegaurd came on after fitting. He has wires it into the front interiot light with connectors so I cant see that being the problem.
    Feb 2011
    Selby
    Sounds like he may have unplugged or damaged the ribbon cable going from the REC to the ultrasonic sensors underneath the front interior lights when he had the roof lining down to fit the rear interior lights.
    You'll need to get to the plug on the ultrasonics and check for continuity to the other end of the loom at the back of the car where it plugs into the REC. You should be able to do this without dropping the whole of the lining.
    Hopefully it's just pulled out of the connector and will push back in and be fine.
  1. safegaurd = ???
    By bradley in forum Diesel Engine related
    Last Post: 23rd December 2009, 19:46
  2. check safegaurd
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2009, 12:28
  3. check safegaurd problem
    By luckyjohn99 in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2009, 07:33
