Thread: cruise control?...
    Sep 2010
    Default cruise control?...
    Anyone notice cruise control only works after you have pressed the bake pedal?..... (not every time you understand,.. just the once!)... wondering why this is
    Feb 2011
    Selby
    Correct - it says this in the Owner's Handbook. It's a safety feature - all factory fitted cruise control systems have to have a secondary 'arming' action. On some cars it's pressing the brake pedal once the engine has been started, on some it's a separate switch to enable cruise control, and no doubt there are other things around.
    WGAF#5
    yep its to ensure that the brake circuit works ...
    as you have multiple methods for canceling Cruise
    press the cancel/pause button on the stalk
    press the brake pedal
    press the clutch pedal (if you have a manual)
    most manufacturers have this "feature" fitted to ensure that the circuits working correctly prior to allowing the cruise to operate/function
    Sep 2010
    proves reading the handbook is a good idea really!
    Or put the autobox into neutral.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
