Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Towing a car and trailer with a Vxr estate
    bedford
    Default Towing a car and trailer with a Vxr estate
    Dose anyone on here use a vectra Vxr estate to tow a car we need to trasport our Astra Vxr track car but not sure if it will be to heavy for the vectra the car should weigh about 1150 ish when finished plus the weight of the trailer which I still need to buy yet but can't seem to find weights of trailers very easy anyone know the max I car pull with it ? Also what towbars have people fitted to Vxr estates ?
    Thanks craig
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Its the second weight on the chasssis number about 3200kg
    bedford
    Just had a look it's 3390 how do I work it out from that I'm new to towing we normaly use our transit recovery truck but it's costing to much to tax etc for it just to sit there and not get used much
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Take the weight of the car off that. Whats left is the weight your allowed to tow I gess about 2000kg
    Regular Member poves's Avatar
    lancashire
    I'm going to stick my neck out here and say you will be overweight , if common sense prevails - how can you tow something legally , which weighs more than the car your towing with ? so if your car weighs around 1400 kg at a guess , surely you cant tow 2000 kg
    I was under the impression it was around 80% of your cars weight (so say around 1100 kg ) which would be the astra plus another 3-400kg for your trailer. If your trailer has twin axles it also needs to be braked on both axles , and be fitted with a breakaway line .
    Towing trailers is a risky occupation these days .
    lancashire
    According to this you may be ok , but definately make sure before .
    Aug 2011
    ASDDA
    I will keep my neck here and say that you will be overweight if common sense prevails - how can you get something that weighs more than legally tow your car? So if your car weighs about 1400 kg at a guess, you can not pull 2000 kg was under the impression that it was about 80% of your weight cars (so to speak, about 1100 kg) Astra is the most another 300 to 400 kg trailer. If your trailer has double axle, it must also be stopped on both axles, and be equipped with a line break. Trailer towing is a risky business in those days.
    lancashire
    Can an admin ban this muppet spambot
    Glasgow
    Quote Originally Posted by tomaasbark View Post
    Tera Gold Tera Online Tera Gold
    One word springs to mind, starts in A and ends in E.
    Leicester
    You will be fine. It's the kerbweight you will need to look at.
    If your Astra weighs 1150kg's and the trailer comes in at say 200kg's you will have a total of 1350kg's.
    That is no more than your average 4 berth caravan. I can't work it out exactly as I am in Los Angeles at the moment but our caravan is 1455kgs an my old Vectra Sri 150 CDTi we were towin at 95% of the kerbweigt which is perfectly safe for the experience tower. Now I know that the Vectra VXR was better because we looked at buying on.
  1. Max towing weight - CDTI estate
    By zafira in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 15:51
  2. Vectra 1.8i VVT Estate for towing caravan???
    By fastbatard in forum Introduce yourself.
    Last Post: 26th November 2010, 11:54
  3. Red Preface SRi on Black Rims towing a trailer!!!
    By tomtaylor15 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 21st September 2010, 18:11
  4. SRi XP CDTi 150 Estate Towing????
    By HA54SYM in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2007, 11:27
vwctra vxr estate towing
