Thread: oil catch tank
    Regular Member spidermonkey's Avatar
    Jun 2011
    mexborough
    Default oil catch tank
    has anyone got a picture of the tank fitted to a vectrs 1.9cdti (150) just want to know which hose to fit ti to.
    Sodding Typical on Sea
    Hi Mate yo fit it to the pipe that comes off the cyclone on the rear of the cam cover, a rubber hose comes off that attaches to a metal transverse pipe that then goes to the inlet after the MAF.
    On an Atmos venting system block the metal end at the rear with a piece of 15mm oil proof hose, and then feed the hose from the cyclone to the catch tank then vent a second pipe down to the bottom of the bulkhead.
    On a closed cycle system, vent from the cyclone via the catch tank, then back to the transverse pipe on the left so that fumes are drawn back into the intake stream.
    Feb 2011
    London
    still not clear about this. so for a closed system one would need to remove pipe that is circled.plumb it to the catch tank and then pipe from catch tank back to where we removed pipe originally?? and nothing else??
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    To vent to atmos simply attach a length of garden hose into the end of your circled hose (part where it goes into the metal pipe on-top of the engine), Then part the same metal pipe/ rubber hose at the other eng (front of engine) & blank rubber hose as shown earlier (with a large bolt or short term i used a short length of 15mm copper pipe with the end bent over).
  1. oil catch tank.
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 00:32
  2. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  3. Oil catch tank
    Last Post: 23rd December 2011, 16:04
  4. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  5. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
vectra c oil catch tank
