Results 1 to 10 of 15
Thread: Caliper mount bolts
    berkshire
    confused Caliper mount bolts
    Ok so like many the back brakes needs new discs/pads. Many threads (also haynes) state new bolts to be used. Fair enough but if this is the case why does not one Vx dealer in Berkshire stock any? Surley they change them as advised on their many disc swaps a week in house & would readily stock them??
    So is it COMPLETELY needed or have people not bothered & still braking happily? I read again in many posts to damaged heads due to the high torque settings so think I would rather play safe & have some new spares ready! I just dont understand why not easier available. Any thoughts please...
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    I cleaned mine up and re locktite them
    Local Vauxhall garage told me they re-use the existing ones once cleaned up obviously.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    iv reused mine as well
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    as above
    As long as you clean off the old locktite before re-using perfectly ok .
    and still loving it
    berkshire
    Well you've both lived to tell the tale I guess. I just know a job isn't done till something goes wrong first. Stripped head etc.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Is the LocTite a necessity? (Probably a daft question)
    Quote Originally Posted by DeeBe View Post
    Well it was used in the original assembly process on the production line.
    Depends how confident you feel about your nuts not coming loose.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I believe one of the main reasons for the Loctite is also to stop water ingress up the threads. There torqued up so tight, if they also rusted they would be impossible to get off without heat.
    Jun 2011
    South Shields
    That's what I though rushy. I had to use a torch to get mine off last week. I used Coppaslip when I put them back in. Never had any bother on previous cars... :S
  1. Caliper bolts....
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2012, 12:02
  2. Strut top mount bolts...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 29th February 2012, 21:51
  3. Front engine mount bolts
    By johnnyallen in forum Engine & Drivetrain
    Last Post: 23rd April 2010, 08:34
  4. Caliper guide bolts
    By vec04 in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 23:23
insignia brake caliper guide bolt torque setting
vauxhall caliper mount bolt
vectra c caliper guide bolts
