Results 1 to 10 of 13
Thread: here we go! hassle after my overhaul.......
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default here we go! hassle after my overhaul.......
    ok my gsi has had a fair bit of work recently, cambelt, plugs, rocker gaskets, and other stuff so my engine has been apart.
    noticed the other day when the car was on axle stands if i rocked the ns/f whell back nd forth there was a clunk clunk clunk noise comming from the gearbox. assume this aint normal
    but car changes gears fine nice and smooth. but yesterday i noticed that i was in second gear and the only way i can explain it is that i had a blip a very quick jerk almost make sence? it has also done it in forth aswell.
    its done it a couple of time now, do you chaps reckon it would be the box on its way out or maybe something engine related? i cant put my finger on weather its the engine or box. cheers for any insight. Tim
    Full Member Big Sig's Avatar
    CV joint or drive shaft?
    Nov 2010
    BRECHIN
    dont think so, 99% sure the knocking cluck was from inside the box. if i place my hand on the end of the box you could feel it inside
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Nothing wrong with it mate. Every car will clunk when you do that. Its just th box etc taking up.
    Nov 2010
    BRECHIN
    thats great! fantastic news! cheers, will probably look in to giving the box an oil change then, just for a freshen up. so must be something engine related then. hmmmmm wonder what????
    my rear bank coilpack was completley flooded with oil hole for the plugs were full to the brim because of a failed rocker gasket so im gonna maybe point my finger in that general direction. gonna run it and see what happens next lol
    Quote Originally Posted by sdemps View Post
    all gearboxes have some backlash, the more miles the worse it will get. Nothing to worry about really.
    New oil in the box can only be a good thing
    Nov 2007
    Ayrshire
    The noise your hearing is from the box but its perfectly normal to hear and feel it when "rocking" the wheel. A brand new car will do exactly the same. Don`t worry about it at all.
    Nov 2010
    BRECHIN
    well the cars sitting with 77k on her. so i verymuch doubt the oil has ever been changed so will get it done. as for my blips lol will take her out for a good spirited drive and go from there. has to be something ive done whilei had it stripped down for the plugs and gaskets.
    Nov 2010
    BRECHIN
    cheers, what i found strange is tho, when say your on the road wife driving along, and she comes off the power then on again you can hear the clunk. that really started to worry me! hopefully an oil change will quieten it down a tad. its not loud at atall but noticeable.
    Check the rear engine/gearbox mount as they are a common failure on the bigger power vecs !!!!
  1. suspension overhaul
    By beat275 in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 13:26
  2. 2.2. Direct h.p fuel pump.can i overhaul original.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd May 2012, 22:30
  3. Alloy wheel overhaul help
    By R2XPT in forum Detailing and Car Care Discussion
    Last Post: 16th August 2011, 18:47
  4. z22se engine overhaul
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 4th February 2010, 01:44
  5. How much hassle is it....
    By philzi in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2005, 10:20
