Results 1 to 10 of 15
Thread: V6 CDTi exhaust replacement...
    Jun 2011
    Elland
    confused V6 CDTi exhaust replacement...
    Just noticed that the back boxes are starting to badly corrode on my signum. Cheaper to go stainless or genuine??
    Seen a vectra stainless system on ebay for 400£ and I know a very competent welder if it needs modding to fit, is this worth going for as a replacement?
    Anyone done similar? Not wanting to spend mega bucks on modding, just want a functioning exhaust... but if it soulnd a little better to boot, I won't mind
    Bristol
    It maybe just the outer skin coming off. it happened to mine a year ago removed them and they are still sound. So try that.
    Agreed, mine were first reported on MoT as badly corroded in 2009 and look exactly the same now as they did then
    As with all exhaust parts, wait until they start blowing and need replacing
    Jun 2011
    Elland
    OK, I didn't realise they were double skinned
    This means they're likely to be an expensive original part, so I think I'll wait till it's totally knackered, then go stainless, thanks!
    i think a genuine rear box from stealer is around the £380 mark
    could get a cat back stainless from mij for less
    mine have also started to deteriorate
    Bristol
    The last time I checked aftermarket boxes not sri were about £100 each
    Regular Member Jezzy's Avatar
    S.E
    Trade Club prices for Vauxhall rear boxes for the Z30DT (I'm just guessing at which version of the 3.0 you have) range from £100 to £136, plus VAT.
    Jun 2011
    Elland
    Yes m8 it is the Z30 engine. Bit of variation in prices, but even at 120-150£ per box, plus the pipework, it would probably work out similar to go 'fit and forget'. Now, if I could ditch the DPF, that I think is dinsintgegrating due to the appearance of black soot in the tailpipe, I would really be getting somewhere...
    Think you'll find the rear boxes on the 3.0 are one piece , there not like the quads you get with the y piece
    Bristol
    On the pre facelift they are seperate boxes either side
  1. Z30DT Exhaust Replacement
    By ph67 in forum Y & Z30DT Specific
    Last Post: 12th December 2011, 14:42
  2. V6 CDTi replacement exhaust
    By JonV6 in forum Diesel Engine related
    Last Post: 8th April 2009, 07:42
  3. New Exhaust System or part replacement
    By sycho666 in forum Petrol Engine related
    Last Post: 6th January 2009, 19:27
  4. Replacement Exhaust for 2.0 Turbo??
    By Nidge in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 20:07
  5. Replacement Exhaust Advice
    By 24vElite in forum Petrol Engine related
    Last Post: 8th June 2007, 14:35
