Thread: Cdti 150 overheating
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Default Cdti 150 overheating
    Hello, my mate has got a 150 cdti on a 58 plate with 56k on and it overheats when driving within minutes, i have checked the water pump is turning, my questions are do the thermostats stick shut on cdti's and could the water pump shear off on the inside because the water is not circulating back in to the header tank, heaters blow red hot but water in header tank remains luke warm, any ideas, Thankyou.
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    sounds like the waterpump.... think i have heard of these shearing.... Wont be a thermostat issue as it wouldnt overheat within a matter of minutes
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    If the water pump is working you should be able to see water returning to the header tank regardless of what the thermostat is doing. If you cant, my money would be on a failed water pump too, thermostats are designed to jam open when they fail these days. Not saying its not the stat, just highly unlikely.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Could be water pump. Unlikely to be stat as they jam open (as said above). Is there pressure in the tank when you remove the cap or any white smoke from the exhaust (possible head gasket failure if so )
    On the back wheel
    Thankyou, water pump is what i thought as there is no water returning to the header tank,
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Same as mine Returned home today and temp was at 105deg and fans going full pelt! Had a look and no coolant flowing back. So will have to wait until Tuesday now
    On the back wheel
    Turned out my mates water pump impeller had come loose on the back of the water pump so i changed the pump and now its ok.
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  3. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
signum cdti over heating
astra overheating 2.0 cdti
