Results 1 to 10 of 13
Thread: DTi boiled!
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default DTi boiled!
    Right CIM is shot so dash not working, so just 20mins ago I've driven 30miles home from a BBQ and half way I go into limp mode so I'm thinking time to clean the egr, when the dash eventually comes to life the temp needle is through the roof!!! So pulled over immediately and on inspection the alternator belt has snapped so not turning the water pump. What damage do you think is likely in this situation? is the water pump impeller plastic meaning ive probably melted it? Would the head gasket go under such hot conditions?
    I'm soo annoyed ive missed it over heating cos the CIM is packed up, but I guess that's life
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Water pump will be goosed.
    Might be lucky with just that. But you won't no until it's running again.
    Apr 2009
    Stevenage, Herts
    Oh s**t! Can't afford it right now as just blown £550 on four Tyres and four wheel alignment! I hate cars!
    Tomorrow I'm going to take the front wheel off and see if I can put a new belt on myself, if so run it up and see if it overheats. Got a feeling though there's not enough room in there for me to do the belt myself so will probably have to get it done anyway. Never rains hey?
    Engine : 1.9 CDTi
    What engine do you have as the cambelt runs the water pump on most cars now
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by lee gsi View Post
    2002 2.2DTi, the belt is defo snapped.
    Regular Member Jezzy's Avatar
    S.E
    2.2 DTi
    Apr 2009
    Stevenage, Herts
    FOUND the problem when I investigated this morning, the crank pulley has sheered off!!! Found it sitting in the wheel arch guard under it! My mechanic is coming out to fix it tomorrow, probably gonna need a new water pump I expect . Pics of the damage below, GUTTED!
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    thats a ****ter mate, hopefully not to much else fubarred
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Holly **** :O
    Hope it's sorted easily enough mate
    West Sussex
    Quote Originally Posted by si_hoss View Post
    Whatever you do don't get a cheap after market pulley like I did, you'll regret it! A pukka part with a new stretch bolt is about £220.
    And you'll need a good quality impact gun to get the old bolt out.
