Results 1 to 10 of 30
Thread: Short measure at the pump!
    Regular Member Old man Jimbo's Avatar
    Jul 2009
    Cumbria
    Default Short measure at the pump!
    What would you do?
    Long story short. Went to top up tonight on route to a well known fast-food joint with wife and kids. So pulled in at the local Shell garage to top up as I was just under half a tank on the gauge. So gets out of the car plucks the V power nozzle and go into daydream mode. Thinks to myself "god this pump is slow" and looks up to see £80! **** me that's 56 litres! I stop the pump and go into get the manager.
    Well I was basically told there is no manager and pay up and funk off! They made no attempt to look at the pump or switch it off or anything. So I hopped back into my car swearing and cursing started it up and the gauge didn't even go to full! I looked in the handbook and the tank (estate) only holds 60 litres FFS!
    To say I'm a little upset and angry would be a slight understatement and I know VXR's are thirsty but TBF that episode works out at £160 a tank.
    So in short what would you do? I'd love to rob £80 out of the till but I feel I'd go to jail for that but it seems if you're a garage you just call people liars and kick them out.
    Help. I really mean it aswell help!
    Regular Member meridian9's Avatar
    Jul 2010
    Blackpool
    Vehicle : Vauxhall Insignia
    Trim : SRI Nav
    Engine : CDTI 160
    Report it to your local council trading standards department, they'll go out and take measurements from the pump if you tell them which pump it was.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    take a 5 litre can and fill it up to prove it one way or another
    Mar 2011
    llandrindod wells
    i would also have taken photos as evidence
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Should have told the staff "I'll be back".
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Trading standards are your best bet. But in the mean time id nip back with a 5lt can fill it up as triple595 said, if it says 10lt id be telling the staff to get the owner of the station down asap!!!
    Regular Member BoroDave74's Avatar
    Oct 2008
    Attleborough
    Please ignore the 5l can suggestions; there isnt a 5l can out there that is 5l, they're all made much larger than that. It'll be a waste of time and effort and only rile you up further. Whilst meant well, it's not a practical solution.
    If you wish to complain, call Consumer Direct with the details of your complaint: Where, when, pump number etc they have the script we gave them so they should ask for this anyway. CD pass the info directly on to the TS department responsible for Metrology in the relevant area.
    An Inspector of Weights and Measures will go and check the pump for correct measure and correct operation ensuring the seals are correct and it conformd to the type approval. As posted before, the legal accuracy of the measure on inspection must be within +/-1%. The site register will clearly show if anyone has been in between your complaint and the inspection, as would the sealing mechanisms, and no doubt any self-verification notifcation sent through to the LA. The Inspector would normally then contact you to explain their findings.
    As for the discrepancy between handbook and pump display that's more than likely to be down to the fact that your fuel tank plus connections and pipe volume is much larger than 60 litres. Fuel tanks are mass-produced and are not volumetrically measured; 60 litres is a guide, as is your fuel gauge - a guide, no claim is made by any manufacturer as to any accuracy, particularly not in comparison with a verified measuring instrument. I know my vec's gauge isn't accurate and I do a fairly similar weekly run and fill up at odd times; but whist the gauge frequently appears random the literage and mileage work out in the end.
    It is possible there has been maintenance on the pump and there is a problem with the pulsar or the software, in which case this will be clearly visible in the discrepancy between sales and stocks: you aren't the only person who uses that pump. In which case the operator will reimburse you.
    No doubt the staff will have made a note of the incident and will be expecting the inspection. They certainly wouldn't be either trained or expected to touch any of the workings of the equipment. They may out of site policy take that particular pump out of use, until an engineer has been out to check the correct operation.
    Honest opinion after 11 years inspecting and enforcing this? You got 56 litres of V power. Whilst not the response you're really hoping for, at least you've got the advice above as to how you can proceed correctly if you wish to complain and what you can expect to happen either way.
    spoons
    Guest
    This happened to my girlfriend the other day !!
    She had qtr tank of fuel left and filled up with 33 litres. The tank only holds 30 litres !!
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Could also try explaing this to Shell Head Office.
    Quote Originally Posted by spoons View Post
    What car only has a 30 litre fuel tank...?
  1. how can I measure boost, air mass and air-fue ratio
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 12:59
  2. Please measure you knobs
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 20:45
  3. rear camber measure/ajust
    By hapsdoggen in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 21:58
  4. Alternative traffic calming measure
    By Swatty in forum General Chat
    Last Post: 24th November 2006, 22:19
