Thread: 1.30 DPF or not??????
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Default 1.30 DPF or not??????
    hi guys, remember reading somewhere a while back that if the sticker inside your drivers door reads .50 it means you have a DPF but if it 1.20 or up you dont. is this right??
    thanks in advance
    May 2011
    Bump
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yes 1.20 is no DPF and 0.5 is a car fitted with DPF.
    1.30 refers to the 3.0CDTI and CDTI 120's and from the way the numbers are put on the 150, I would say a car with 1.30 means it doesn't have a DPF.
    May 2011
    Cheers Gazza4, I thought It was from what I remember but wanted to make sure before I make blanking plate at work for my egr
    Stu
vectra 1.30 dpf
