Thread: What fuse for interion light?
    Regular Member amd's Avatar
    Oct 2009
    Lithuania
    Default What fuse for interion light?
    Hello,
    after trying to replace glove box lamp to led, i noticed that it not works, then placed old one, and it do not light too. After that there is no light on roof and in boot. Any ideas where is the problem? tried search for bad fuse, but cant find :-(
    Signum 07'
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hmmm
    "interior light fails to work after working on the glove box light"
    The obvious one for me here is Fuse 12 at the end of the dash panel.
    This is the BCM overload protection fuse... this often blows when people work on the glove box light.
    Oct 2009
    Lithuania
    Thanks Robsey, 12 fuse was dead.
    Worcs/Staffs/Westmids (ish)
    Excellent! Just the topic I was looking for!
    What's the rating of this fuse??
    I want to tap into the supply to the manual interior light switch and use it to power an onboard camera mounted behind the rear view mirror (around 500mA to 900mA), without having leads and cables all over the shop.
    By my estimation, the interior lights are 2 x 5w bulbs = 840mA @ 12v
    I have LED's fitted instead of w5w's, so in theory I should have plenty of power to play with.... Unless the supply to the manual switch doesn't in fact bypass the control module.
    Anyone know?
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Should be enough to run a camera...
    I tapped into the interior light to provide a direct feed to a rear interior light panel.. think this has two 5 watt bulbs in it.
    I have had no problems since doing the installation.
  1. instrument light fuse ?
    By neilb1 in forum The 'Off Topic' room
    Last Post: 20th March 2012, 10:26
  2. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  3. FOG LIGHT - FUSE HELP REQ- Urgent
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 12:49
  4. Replies: 13
    Last Post: 30th December 2010, 20:05
  5. rear fog light fuse
    By thedrive in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2009, 19:11
