Thread: 12v switch
    Sep 2009
    Glasgow
    Default 12v switch
    just a quick one installing my front sensors today, planning powering them from a dash mounted switch, what switches at maplin would be ok. or i might just keep them perm on.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Jul 2009
    The Rift, Cardiff
    I'm not sure if maplins sell them but I've seen relays with a ~30 second delay. So you could wire it so that when you engage reverse both the front and rear sensors are active, then when you come out of reverse the front are still powered for the ~30 seconds.
    Sep 2009
    Glasgow
    seen that option ta mate.
    Jul 2009
    The Rift, Cardiff
    If you can't get a delay relay any 12v switch will do but it'd be best to get an illuminated switch so you know when they're on. I think the most subtle/flush fit illuminated ones maplins sell are square-ish with a round rocker or push button.
    Sep 2009
    Glasgow
    yep got a red one , i was going to run the sensors from the 12v ign live from the headlight plug attached to the switch, i hope it works. the switch has 3 terminals what one is pos neg and illuminate switch, cant see any markings on it.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by nokiaman1978 View Post
    Have you got an electrical meter, could check on/off. Iirc, there is no negative, the switch interupts the live supply, earth is to illuminate switch.
    Sep 2009
    Glasgow
    got a meter dont know how to use it though
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
