Thread: Copper Grease on Engine Components?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Copper Grease on Engine Components?
    I have a constant squeak noise coming from the alternator belt on cold starts, it seems to be coming from one of the cogs on the left side of the engine, when I spray WD40 into the [bearing ???] part, it stops for a short while but then just evaporates.
    I have a spray can of copper grease, if I spray this in the same spot will it do anything bad to the cogs, after all it is for high temperature situations, but I've read about not spraying it on certain alloys?
    The noise is really annoying me sounds like I have a banger when my engine is started. If copper grease is no good can someone recommend something else?
    Thanks!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    change the belt only a few quid
    Mar 2011
    Wirral
    But then how much for someone to do it, as a quick fix?
    north east
    get the belt and tensioner replaced, its all good to prove the fault with the likes of wd40 / copper grease but when you think thats going to be spinning at x000 rpms if your lucky its snaps and does no more damage, if your unlucky it snaps and wipes out some expensive components.
    Regular Member eaglepva's Avatar
    Up North
    I have the same noise on start up to mate, going to try and spray some wd40 where you have said then seen if it stops.
    Mar 2011
    Wirral
    Yeah I suppose you are right I'm just masking the problem, gonna get my cambelt changed soon so will get it done with that!
  1. copper pipe
    By fattony in forum Engine & Drivetrain
    Last Post: 12th October 2012, 22:25
  2. copper grease on wheel nuts
    By J P S in forum Suspension, Wheels & Brakes
    Last Post: 6th October 2011, 01:17
  3. just reported a copper for doing well over 40 in a 30
    By monty2000 in forum General Chat
    Last Post: 3rd July 2010, 10:04
  4. Helpful copper!
    By the_wave_rider in forum General Chat
    Last Post: 2nd July 2010, 20:44
