Thread: 3.2GSi 'leaking' what looks like water - should I be worried?
    Regular Member dlp's Avatar
    Mar 2011
    Cottesmore, Rutland
    Default 3.2GSi 'leaking' what looks like water - should I be worried?
    OK so I just stopped at my second home and when I went to get back in the car I noticed it had had a little (well quite a fair sized) wee...
    It isn't petrol and I'm fairly sure it is water (cold, clear, odourless, very light/watery). The leak appears to be coming from a pipe which comes out of the bulkhead on just on the drivers side of the centre and terminates.
    Is this 'just' something to do with the aircon, is it something else entirely, should I be worried?
    All other levels look OK but it did *seem* to me that the engine was running a little hotter than normal between home number 2 and home number 1 - but this is most likely my imagination (I hope).
    Any help appreciated, I have done a cursory search but haven't found anything: thought I'd post and then go for a proper trawl as I'm s'posed to drive to Lahndan tomorrow...
    Engine : 1.9 CDTi
    Sounds like the condensation draining from having the aircon on.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Jun 2011
    Elland
    Aye m8, it does!
    Keep an eye on fluids if you're concerned, though
    Oh, and having the aircon on not only places additional load on the engine, but it also throws the heat it removes from the interior of the car right in front of the radiator (on most setups), so having it run a little warmer is not unreasonable.
    Mar 2011
    Cottesmore, Rutland
    Thanks chaps, that's what I thought (couldn't figure where 'clean' water would be coming from otherwise...).
  1. o2 Router leaking water
    By bigmac in forum General Chat
    Last Post: 30th October 2012, 16:34
  2. water leaking
    By jinkie in forum Engine & Drivetrain
    Last Post: 14th August 2012, 19:51
  3. Water leaking in car fix -* VIDEO *-
    By shammon in forum Bodywork & Interior
    Last Post: 28th April 2012, 19:47
  4. Oh No....Water Leaking into Boot!
    By chrisschild in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 18:48
  5. Leaking water
    By peter142 in forum Engine & Drivetrain
    Last Post: 5th September 2007, 15:10
water leaking from vectra 3.2 gsi
