Thread: Fuel filter change?
    Sep 2010
    bolton
    Default Fuel filter change?
    i need to change the inline filter at the back of my signum as its coroded, is there anything i need to know about doing it or is it just a case of take it off and put new one on?
    any advice much appreciated,
    cheers
    Engine : 1.9 CDTi
    If its a petrol there should be an arrow on it shwing what way the fuel flows.
    Also be careful of the plastic clips (Dont force them too much)
    Sep 2010
    bolton
    yes its petrol 3.2v6, thanks for that
    Regular Member Jezzy's Avatar
    S.E
    Depressurise the fuel system first, by pressing the pin on the schrader valve that will be somewhere in the engine bay; it will look like a tyre valve, but don't press the A/C one instead.
    Apr 2011
    essex
    i changed mine yesterday its a 2.2 petrol but id imagine its the same. when depressurising put a rag over the valve and then use the screwdriver to push down it saves petrol going everywhere. keep pressing till nothing comes out it took about 30 secs for me.before i did that though and i clamped the fuel line before the filter so it didnt leak when disconnecting the filter aswell. hope this helps
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    where is it on a 2.2
    Apr 2011
    essex
    it's on the driver side rear if you look where the jack up point is marked on the skirt ,its halfway between that and the rear wheel. hope this helps
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    cheers mate
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  3. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
  4. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
