Thread: tailgate interior trim panel removal
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    confused tailgate interior trim panel removal
    I am trying to remove the interior trim panel from the inside of the tailgate on a vectra.. There are 4 plastic pins/studs that hold the bottom part in place, is there a way of removing these things without wrecking them.. Are they reusable or do i need to buy some new ones?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Are they the ones u push the middle thru nige if so u can re use them if u don't lose the middle pins
    Jun 2009
    South Coast
    6 Post(s)
    i wish they were the plastic rivet type but they're not..
    Jun 2012
    Warrington
    Did you manage to find out how 2 remove & refit this itailgate interior trim & where to get the fixings from. I need to do,the same... Thanks in anticipation..
    Regular Member wafoo's Avatar
    West Sussex
    Vehicle : 1.8 Life
    Trim : Life
    Engine : Z18XE
    I had the same problem. See the my post 'Help! Hatch Trim Removal', last post 16th Feb 2012, Page 9.
    West Sussex
    Vehicle : 1.8 Life
    Trim : Life
    Engine : Z18XE
    I've just re-read the original question and see that it relates to the four studs that hold the bottom part in place. These simply pull straight out; I used a small pair of bent-nosed pliers if I remember correctly. Just open the pliers enough to fit each side of the stud and gently ease them under the head of the stud and the trim. They should come out intact and be reuseable.
  1. Signum interior panel removal?
    By DHobbs in forum Bodywork & Interior
    Last Post: 25th January 2011, 10:00
  2. Interior trim removal.
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 00:25
  3. Removing Signum Rear tailgate Interior Trim & Panel
    By Signumv6man in forum Bodywork & Interior
    Last Post: 21st December 2008, 17:43
  4. Remove Interior Signum Tailgate Trims/Panel
    By Signumv6man in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2008, 07:58
  5. Estate tailgate interior trim removal
    By parapaul in forum Bodywork & Interior
    Last Post: 27th December 2006, 14:24
remove inside cover of tailgate vauxhall vectra c
