Thread: Diesel Filter - Help
    May 2011
    Livingston
    Default Diesel Filter - Help
    morning guys, how do you remove the fuel pipes from the top of the fuel filter housing...... just serviced the car....and this is the last thing i need to do.... ? Any ideas?
    Sodding Typical on Sea
    There is or was a how-2 on here but I was still a wee bit unsure of how to remove those blue clips myself! so much so I am going to ask the dealer to do mine for me next month.
    I am sure someone will be along who will explain and me me feel a bit dum for not figuring it out as well mate
    Jun 2011
    Elland
    It's just a retaining spring clip mechanism - a bit like a one way clip sort of thing.
    Look closely and you will see 2 blue lugs that engage in shaped holes, so that the pipe locks in place.
    The lugs both have to be depressed whilst pulling the pipe out. There is probably a VX tool to do this in seconds. You can use a couple of flat bladed screwdrivers - I used eating knives as my weapon of choice
    The first time you do it, it's a bit fiddly, as you get one lug pressed in, then the other pops back on the other side. You feel you need a third hand for the job (Ooo-er). I got quite adept at it, whilst trying to sort out my fuel leak / air leak probs!!
    Jul 2010
    Londonderry Northern Ireland
    make sure replace the seal or you could end up with a shower in diesel!!
    May 2011
    Livingston
    Thanks for the replies guys, managed to sort that, you the hoses off, but for the life of me could not get the top off the plastic filter holder, it is on do damn tight?
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    normally its removed from the car and gripped in a vice and then the top is undone.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    if its anything like its petrol equivalent mine was a right pita, just as well i got new clips for it at the same time
    Jul 2010
    there is a special tool for doing the job
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by houston View Post
    Be very gentle with it - especially the hose connectors and the part on the filter housing they connect into as they can easily be damaged and you need to replace the whole housing which ain't cheap. The main housing body and screw top aren't that strong either so be careful
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diesel filter
    By G4GAV in forum Diesel Engine related
    Last Post: 2nd October 2010, 15:04
  3. K&N Air filter for a diesel
    By shamus5178 in forum Diesel Engine related
    Last Post: 16th February 2010, 21:35
  4. where is the diesel filter???
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 22:26
  5. Diesel Filter?
    By thewww2 in forum Engine & Drivetrain
    Last Post: 21st April 2006, 21:26
