Results 1 to 10 of 13
Thread: Weird.....
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Angry Weird.....
    Ok so im my pursuit of retrofitting factory foglights I got around to fitting a fusebox that supported front foglights. No issue there swapped over in less than 10 minutes. So I head over to the guy I know with Tech2 to activate them. So hook tech2 up, activate the fogs and the GID tells us to check foglight on the left and right as if the bulb is blown but I know both bulbs are fine. Indicator on dash works ok but for some reason the canbus system thinks the bulbs are blown and the foglights dont work. Looking at the side of the new fuse box and the date on it is 09/04 so more than likely its full can and my car is half can, could this be the issue?
    Ok it gets better. My headlight washers aren't working with this "New" fusebox either so I decided to swap back to my original fuse box. So 10minutes later its swapped back, i go to check everything and set the windows, stereo and check the headlight washers but the car wont start, nothing, range showing Zero on the GID and the steering wheel symbol on the dash. So go and check all the connections in the fusebox, and #17 at end of dash too, all ok, all fuses fully pushed in and all relays in fully too. Yup panic sets in!!!!!!! So I decide to swap back the "new" fusebox and the car starts fine. Swap old fusebox back again just to be sure its not working and yup car wont start. "New" one refitted again. So looks like a trip to U Pull tomorrow to see if I can get another fusebox and take it from there........Thing is I have taken the old fusebox apart and all there is is PCB and 2 small black modules in there. Is it possible that when reconnecting the battery(I only disconnected the short live lead to the fusebox at both ends) that one of the small black modules has shorted out and prevented the car from starting?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    ****** od m8, but I think the moment batteries and fuesboxes are removed from the car, the gremlins seem to awake.
    Either way the problem is most likely the fusebox if the car is starting ok.
    As for the canbus system I did say - avoid wiring and activating lights into it's bulb check system. Mine has decided to pop the passenger bulb. ****** irritating. Thing is I have never had those fogs on since I changed them to the SRI style ones.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Well you headlight washers do work on the new one... but they changed the way it was working.. atleast for modelyear 2006, where it made the complete facelift.. (the popout washers...) the preface makes 2 pulses.. where on facelift only one..
    No i wouldt belive its the new UEC thats the problem on your car with the bulb blown.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Yea starting to think that way too Gazza.
    Kenp thought that washers were activated in the BCM though not the UEC? As for the bulbs well they are not blown that's the weird thing. Looks like im gonna give up with the full retrofit of the fogs tbh, its annoying. What about the car not starting with the old UEC fitted? Any thoughts?
    Engine : 2.2 Direct
    Nope washers is also in the UEC.
    It sounds strange.. but did you fit the new UEC before the tech2 was on the car? if no maby the tech guy had the old one resat!
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Yes new UEC was fitted before the Tech2 was on it.
    Engine : 2.2 Direct
    Humm then it sounds strange that it wont work with the old one.....
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Ok mate update time.
    I also noticed today that my wipers were only working on intermittent and position 1, when you clicked to position 2 they wouldn't move. Decided to have another look today and by luck decided to have a look at the facelift manual and the list of fuses, low and behold thats the problem, the fusebox is defiantly a facelift one. Headlight washers are position 14 on preface and position 13 on facelift. When I swapped over 7.5 amp fuse in position 13 on facelift fusebox it had blown due to the load the washers drew. There are also 2 fuses for the wipers, 1 must be for intermittent/pos 1 and one for position 2, where on the preface they are together, number 10 and 11, on the facelift fusebox they are number 10 and 22, bl00dy VX!! That still dont explain how the old fuse box has gone from working though.
    So back to square 1 im afraid, still looking for a preface fuse box from an SRi,GSi, Elite. Ill get this foglight Mularkey cracked at some point
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I hope you do bud, seems Vx have made sure it would be difficult to swap stuff about. Why not just keep everything the same?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Cheers mate, these things, as they say, are sent to try us On a "plus" side, im learning more and more everyday on my quest for factory fitted front fog lights Been cheaper just buying an Sri, but where's the fun in that
  1. Weird
    By spoons in forum The 'Off Topic' room
    Last Post: 17th August 2012, 17:49
  2. Weird cut out!
    By Chip in forum Engine & Drivetrain
    Last Post: 4th June 2012, 18:35
  3. Bit Of A Weird One This
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 15:52
  4. em..... am i weird...
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 11:35
  5. Weird???
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 21:15
