Thread: brake pedal travel
    Jun 2011
    brum
    Default brake pedal travel
    Ive read online that this could just be a general issue with these cars but i thought id ask everyone else.
    I have a vectra 07 plate (facelift one), 1.9CDTi. The brakes stop me, and the abs does kick in if i slam the anchors on. But the brake seems a little "weird".
    It travels quite far down (im a fairly new driver, second car, first was a '99 fiesta so i dont have much experience in the "norm"). However if i pump the pedal, it gets solid, 3 or 4 pumps and it gets rock hard near the top of its travel, keep applying a fair bit of pressure and the pedal will slowly creep back down, leave it for 30 seconds and it goes back to travelling down quite far.
    Im not concerned about the safety aspect, it stops me and the abs works, but its the mot that may cause me issue (im not sure). So i was wondering what other peoples vectra were like in this aspect ?
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    you will find the brake pedal creep away if you keep pressure on a diesel is diff to petrol vac is supplied from a vac pump on diesel as its from manifold vac on a petrol its normal for this to happen.
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you are stationary when this happens it is due to the ABS unit reducing the pressure, as it thinks all four wheels are locked, try it with the engine switched off it should be solid mine creeps when stationary but is solid when I am moving or the ignition is off.
    Jun 2011
    brum
    makes sense. what about the issue of travel though ? im gonna check it tomorrow, i believe as long as its 20mm from touching the floor then its passable. But it seems weird how it travels really far, a few pumps and its rock hard at the top of its travel, then 30 seconds later its got full travel again.
    Just something that supposed to happen ?
    Im just curious rather than cautious with it. Waste of 24 hours if i dont learn anything new
    Edit: ah paul that makes sense. Should have guessed that myself, obvious thing really. ABS doing what ABS supposed to, so something in my car does work
    Aug 2010
    Leeds
    Brake fluid is best changed every two years how old is yours?
    Moisture mixes with the fluid.
    Check rear pads how are they & disc thickness?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Jun 2011
    brum
    pads and discs were changed last week (5 hours of banging the front discs with a hammer, not my idea of a weekend really).
    Cars an 07 plate and i doubt its ever been changed. Im running dry on resources at the moment, but next payday , if my vx cards here im gonna go up vx and grab all the goodies for a service (oil, filters e.c.t.). Gonna probably do the brake fluid then after reading online yesterday about it and that being the first answer everyone gave.
    Cheers anyway. I guess its just one of them things. Pretty sure i didnt flip the seals as i went pretty slow with the pistons (first disc change so i caressed the pistons back in :] ). However i wish i knew last week what i know now.. and i would have opened the nipples instead. We live and learn
    11 Post(s)
    As others have said. Pedal creep. Nowt to worry about.
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. clutch and pedal travel
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 4th May 2012, 07:52
  4. Accelerator pedal travel problem
    By AFA82 in forum Engine & Drivetrain
    Last Post: 24th February 2012, 20:42
  5. more pedal travel after upgrade to 314mm
    By fuzzbomUK in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2008, 13:37
brake pedal travel diesels
vectra c brake pedal travel
2008 vectra brake peddal travel
brake pedal slowly sinks to floor vectra 1.9cdti
