Thread: 2.2 Direct Power loss Again
    Regular Member LEEROB695's Avatar
    scunthorpe
    Default 2.2 Direct Power loss Again
    After searching the forum for answers on why my 2006 2.2 Direct signum Suddenly has lost power I have come accross 2 possible causes
    The car seems to hesitate low down revs and seems to want to cut out (No dashboard lights at all)
    1 Cam chain has slipped a tooth
    However wouldnt it run like a bag of spanners and sound rough if it had slipped there has been no noise when engine was turned off and the car sounds no different still quiet and starts ok
    2 MAF Sensor failed
    I have unplugged the MAf and the car behaves no different so could this be faulty
    The fuel pressure regulator has been changed as per recall and the car is covered by a mechanical warranty (unless they have a get out clause but i cant get the car looked at till tuesday and its doing my head in
    ANY ADVICE APPRECIATED
    Thanks in advance
    Regular Member davidlewis24's Avatar
    bridgend / wales
    High pressure fuel pump ? Very common mate
    scunthorpe
    It is a seimens pump but I thought the issue with the HP fuel pump was sorted with the recall for the regualtor?
    bridgend / wales
    Quote Originally Posted by LEEROB695 View Post
    Yes mate it's the seimens pumps that are faulty the new modified ones are continetal I'd be very surprised if your problem is not the high pressure fuel pump mate same problems as I had and there not cheap looking at £250 £300
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    No the siemens fuel pumps are rubbish get a continetal one of eBay
    scunthorpe
    The HP fuel pump never even crossed my mind (when you set off or rev the car it really hessitates) what are the symptoms of a failure would there be no warning lights?
    Also what are your thoughts on the Chain slipping is this a possibility?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    If the chain had slipped you would no mark had the same prob a few weeks back no lights and hesitation turned out it was the pump easy to change 3 bolts but defo get the conti one
    bridgend / wales
    I've had both problems mate the problem you are describing sounds like the fuel pump as they were the same symptoms as mine changed the pump and fired up lovely. When my chain jumped a few teeth the car wouldn't even start
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well as you've already said you unplugged the MAF and ****** all changed, I'd say that's a pretty good starting point. Whip it out, give it a good clean out and a little light oil and whack it back in ..... start with the cheapest probably remedy.
    scunthorpe
    looks clean enough ive also Cleaned the Spark plugs checked airfilter and reset the ECU
    And the wife has just informed me she took the car up to 80mph thinking that it needed a good "BLOW OUT" like my Deisel van she said it got there but it took its time
  1. '55 2.2 Direct loss of power
    By margojerrycat in forum Engine & Drivetrain
    Last Post: 22nd September 2009, 20:42
  2. 2.2 Direct Signum Petrol - Loss of power
    By Binksy2.2Direct in forum Engine & Drivetrain
    Last Post: 9th July 2009, 00:33
  3. Another 2.2 Direct with loss of power...
    By Flaninacupboard in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 10:37
  4. Vectra C, 2.2 direct, power loss- reluctant starter
    By Trebor_Lien in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 22:59
  5. Vectra 2.2 Direct SRI power loss
    By craig123 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2008, 21:07
possible. reasons for loosing power in my 2010vauxhall insignia
2010 vauxhall insignia loses power no lights on dashboard
