Thread: Shockers or Suspension on the way out?
    Sep 2010
    Glasgow
    Default Shockers or Suspension on the way out?
    Hi all
    i have noticed recently that whenever i go over a bump in the road or a very shallow pot hole i am felling a lot more vibration in the steering and it does shake left to right quite a lot
    When the car was last up on a ramp the guy in the garage said that the shocker on the front right was leaking (leftside wasnt checked), could this be the cause of the vibrations?
    if so can anyone recommend which ones to get, bearing in mind i do a lot of motorway driving?
    any help would be greatly appreciated.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i would replace the lot with something like Bilstein B4.. cheaper but way better than the GM shocks.. It would be worth replaceing your droplinks while your at it as they are quite cheap.
    Are you still running on the factory springs as well?
    Sep 2010
    Glasgow
    The droplinks were changed at the last MOT when the pads, discs and callipers were replaces.
    I bought the car last year from arnold sharks so not sure if they were changed before me buying it.
    How much would it cost for the B4's?
    cheers
    Jun 2009
    South Coast
    front shocks http://www.lmfvauxhall.co.uk/Bilstei...nd-Signum.html
    rear shocks http://www.lmfvauxhall.co.uk/Bilstei...nd-Signum.html
    give them a call, they will sort you out..
    Sep 2010
    Glasgow
    thanks for the above.
    is it worth changing the springs at the same time?
    Jun 2009
    South Coast
    i would, well i did actually. I put those shocks on and a set of Eibach springs, they are also cheaper than vauxhall and yet better. It will also lower you car by 30mm.. The ride will be a little harder but the car will handle much better..
    LMF sell the springs as well
    many members on here use this combination for their suspension..
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    as above best to swap for a better set and springs less likely to break lol
    Sep 2010
    Glasgow
    Again thanks for all the info.
    i have been looking on different sites for springs and all i can find is springs that lower your car by up to 30mm, which i dont want to do.
    Can you springs that dont lower your car?
    Mar 2011
    llandrindod wells
    look on euro car parts, you should get oem springs, and they have another w/e offer on
  1. kyb shockers
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 12:54
  2. shockers???
    By marshy200 in forum Handling & Braking
    Last Post: 6th January 2012, 21:50
  3. 3.2 gsi front shockers
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2011, 17:56
  4. rr shockers
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 14:10
  5. Shockers
    By user999998 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:54
