Results 1 to 10 of 22
Thread: ebay polisher/sander
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    confused ebay polisher/sander
    to the guys who know about polishers - detailing....can you tell me am i wasting my money with this?
    http://www.ebay.co.uk/itm/PROFESSION...t_11873wt_1202
    cheers in advance, Andy
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Thats looks pretty much the same as mine as does a very good job.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Nowt wrong with that, if you're starting off with one of those, you might be best testing on a scrap panel first
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    ditto... almost the same as mine and it does a great job.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    gwent
    I got a similar one I got it from Germany I had now for 3 year only thing I would get is different pads for it like 3M
    Jun 2009
    bradford
    Thumbs up
    cheers guys!
    dan - is that because it would be too aggressive?- I could pop over and you could demonstrate on my car
    so would i be better buying one without pads and buy my own?
    thanks again
    Woodbridge
    Test on a scrap panel first as it is a rotary and they are slightly less forgiving than a DA. Heat build up etc. Once you know how to use it you will be fine.
    Jun 2009
    bradford
    ah right...........i'm with you now..............but when used right do a better job than a da?, cheers again
    Andy
    Woodbridge
    TBH you can get the finish the same with both the main difference is the speed. You could complete a car about 2-3 hours quicker with a rotary as it will remove the clear coat faster, hence being a little less forgiving. You will read horror stories about them, but as long as you research on how to use it and practice with it on a scrap panel you will be fine with it. If you do practice on a scrap panel then I suggest you try to burn through the paint just so you know how far you can go on your car before burning through.
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    buy it now is £64.97
    but in the add it states: We offer the Dynamo Power PRO Platinum Deluxe package for the truly unbelievable price of £59.97 for those that place an order before the 5th August, that's 60% off the recommended retail price of £150, buy now!!! Your machine will be available the week commencing the 13th August, IF YOU can't wait, don't order
  1. Silverline 180mm Sander Polisher - 1200W
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 28th April 2011, 11:48
  2. 12V Polisher
    By Tam80 in forum Detailing and Car Care Discussion
    Last Post: 24th March 2011, 13:20
  3. polisher
    By topgun in forum Detailing and Car Care Discussion
    Last Post: 21st May 2010, 10:45
  4. polisher on ebay?
    By corman in forum Detailing and Car Care Discussion
    Last Post: 5th December 2007, 21:25
