Thread: Quick question reference oil change
    Apr 2011
    essex
    Default Quick question reference oil change
    i went to VX to see how much a service would be as could be expected i walked away and im doing it my self. the question is my service history says its had 10/40 oil form the start but when i asked at the service desk he said they always use 5/30 oil ive bought 10/40 but now having second thoughts before i go ahead. what do you recon? its a vectra c elegance 2.2 petrol just hit 60000 miles.
    thanks
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    imo 10w40 will be fine, others may disagree though, was it vx oil or other
    Feb 2011
    Selby
    The difference between 5W30 and 10W40 is pretty marginal. 5W and 10W are both good for the minimum temperatures we get in the UK (both below -20°C) and 30 and 40 are both able to cope with the highest temperatures the non-turbo Vectra engines get to with ease.
    The viscosity isn't that critical as long as it's able to cope with the range of temperatures in the engine. So I wouldn't for example use something like 20W50 in a Vectra, as it's too thick when cold for the fairly close tolerances in these engines. But I would use it in a 1970's Escort for example, which has much bigger oilways that don't need as thin an oil. Similarly in my old Nissan Pulsar GTI-R, I used to use Castrol R 10W60 - because the engine in that car could get the oil to 120°C quite easily on a track day, hence the need for an oil that can stay thick enough at high temperatures.
    What matters more is the chemical composition and API rating - pretty much anything from VX will be suitable.
    Apr 2011
    essex
    thanks, i saved the oil change and filter till last so now i can go finnish off
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If your service intervals were 20k then they have to use 5w30. If there 10k then 10w40 is fine. Always use gm filters as well mate.
    Apr 2011
    essex
    well it was a bit of a panic service if you know what i mean its not due for anoter few k but ive got a lot of important long mile journeys coming up so i wanted to get the car serviced. VX wanted £299 for oil, air, pollen and petrol filters. oil change sump plug+seals spark plugs and change of brake fluid my heart nearly stopped so i went to halfords with trade card and got oil, pollen and petrol filters (air was good) oil, spark plugs and sump plug for £53 and did all that this afternoon. TBH i was botherd about the stamps because its full so far but i thought im not paying 300 for something i can do my self. do you recon ill be alright till next time when ive got the money and time to get GM
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    GM oils HERE mate at very good prices. I do stress though to only use GM oil filters as the none GM filter have been known to break down and trigger the 2.2's achilles heal by blocking to oil jet to the cam chain.
    I have self serviced my 53 plate 2.2 from when the factory warrinty ran out. The way I see it, is that when it comes time to sell its not going to worth anything, having dealer stamps isn't going to increase its value by much and the over all money I will have saved with easily pay for itself.
    Apr 2011
    essex
    do you recon i should redo the oil and filter then next weekend?. A week should be alright? i just wanted it done quickly and had the trade card.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No mate, change the filter for piece of mind if you wish but the oil will be fine.
  1. Quick Polish and Badge Change
    Last Post: 11th March 2013, 15:29
  2. Another quick wash and a slight change...
    By John LE in forum Quick Photo Album
    Last Post: 2nd March 2011, 23:04
  3. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  4. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  5. Question Reference Spraying Vxr Valance
    By pords in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 21:12
