Results 1 to 10 of 21
Thread: oil warning light help
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Default oil warning light help
    Hey guys and girls
    The oil light has just came on is it the case of just topping up and if so what spec oil do I need. It's a 1.9 cdti 150
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    More than likely is that just needs topping but check first!
    5w30 fully synthetic
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    5/30 VX specific fully synthetic. Have you checked the level on the dipstick. Might be worth not driving it until you top it up.
    11 Post(s)
    Quote Originally Posted by nicj View Post
    Hey guys and girls
    Which one?
    The low oil pressure or low level warning light?
    The first one is more serious that the latter.
    If you've got low oil pressure, then the engine must be really low on oil for it to have starved the oil pump for it to trigger the pressure sensor.
    Either way, keep a regular check on your oil level Never rely on a light to tell you - unless it's a car that doesn't have a dipstick.
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Was just above the min so topped up and will keep an eye on it.
    Thanks guys
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Think I have a problem! Topped the oil up the other day but I am still getting the oil light on the dash after a few mile of driving. Checked the oil level again and its just below the maximum. Any ideas what the problem could be?
    Jul 2009
    The Rift, Cardiff
    Is it the light that usually goes off when you start the engine (pressure) or is it in the lcd display (level)?
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    It's definatly definatly the engine oil level ( oil can with wavy line under). Thinking maybe a knackered sensor or something.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like a sensor
    If it was me, I'd get it checked as soon as possible, just in case. Can't really take a risk with low oil level / pressure
    Essex
    Ive got this problem but its only started since I changed the oil to fully synthetic, it also doesn't grip the dip stick well and it doesn't register on it!? Only get the yellow oil light on when doing motorway speeds doesn't come on around town?
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vauxhall vectra C amber oil warning light
vauxhall astra 1.9 cdti amber oil light
https:www.vectra-c.comforumshowthread.php144564-oil-warning-light-help
Opel 1.9 cdti oil warning
opel 1.9 oil level warning light
