Thread: Help Please, Rattle noise like a penny in a coke can!
    Regular Member Henry42's Avatar
    Jun 2011
    South Shields
    Default Help Please, Rattle noise like a penny in a coke can!
    As title says, was parking up at the customs house in South Shields and its a cobbled road, this almighty rattle starting coming from the front right side and the i can only describe the noise as like a shaking a coke can with a penny in it!
    Any ideas Guys, its goin in next thursday for new air con chamber and radiator i believe they said so was going to get this problem fixed at the same time!
    Henry
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    I had an annoying rattle on mine a few months back and I found it was the fixings holding the centre console to the car (the long plastic thingy that goes over the gear stick \handbrake etc)
    The fixings are located to the front, between the gear stick and pedals....
    I hope I've made sense, and I hope it solves your problem as it took me months to find them!
    Jun 2011
    South Shields
    Will have a look cheers for that fella, makes complete sense, did it just re attaching or did you have to buy new components?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I'd say it was either the anti roll bar to subframe bush or the anti roll bar drop links, worn drop links are common, although the good news is that they are cheap and easy to fix.
    I have fitted stronger drop links listed for a saab 9-3 however i can't remember the manufacturers name.
    Aug 2010
    Pontefract
    Quote Originally Posted by Henry42 View Post
    no worries, the fixings were fine they had just worked loose.
    They are very odd fixings though, from memory it was a nut over a screw....?
    Also, reading the other reply I assumed the noise was coming from inside your car so my help may be completely useless! lol
    Regular Member Innes's Avatar
    Plymouth
    My guess was exhaust heatshield has come loose. I'm about to go and fix mine with some washers.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    When my exhaust shield came loose and the bolts sheared i used a good dollop of clear mastic/silicon as a glue n wedged the shield against the mastic with a trolley jack overnight until it cured.
    Plymouth
    If any of mine shear then I'll drill our the broken thread and put in some self tapping screws. But if all else fails then the mastic it will be!! Looks like I'm putting it off til tomorrow now
  1. rattle noise HELP
    By tditony in forum Engine & Drivetrain
    Last Post: 5th May 2010, 09:34
  2. Rattle noise
    By andreitone in forum Engine & Drivetrain
    Last Post: 11th October 2009, 20:45
  3. engine rattle noise
    By fizler316 in forum Engine & Drivetrain
    Last Post: 18th April 2009, 17:30
