Thread: mirrors
    Jul 2011
    UK
    Year : 06
    confused mirrors
    Hi wen I adjust drivers mirror the n/s mirror also moves so have to adjust n/s again anyone no why this happening also both headlights at bottom have started to mist up
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    It's normal. You adjust the passenger side seperately afterwards. It's basically so you can move them both up and down the same if needed for reversing etc. The very early Vecs didn't do it (my old '03 plate didn't for example) but they changed it later on.
    Jul 2011
    UK
    Year : 06
    Oh I have never noticed it before adjusted to reverse and looked n/s and went wtf lol
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Yeah, at home I only need the p/side one down, so I push the button for that, keep forgetting to put it back when I go out.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Feb 2011
    Selby
    The headlights tend to mist up if the rubber caps aren't put back on properly after changing the bulbs. Way more common on pre-facelifts than post.
    Simply wait for a nice warm, dry day. Park facing the sun. Open the bonnet, take off the bulb covers, take out the bulbs. Shut the bonnet and lock the car. Leave it for a couple of hours and the heat of the sun will cause the water to evaporate and leave via the bulb holes. If it's not sunny, you can use a halogen lamp or hair dryer - but don't get too close, the headlights are plastic. You can at a push do it by using the headlight main beam bulbs to heat it up, but I found it worked better using an external heat source.
    Then refit the bulbs and covers.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    also the use of the good ole silicon gel bags put inside the lights......works wonders for the fogs ...works wonders for the headlights too.
    Feb 2011
    Selby
    The silica gel bags work too - but remember to take them out once they've absorbed the water. Otherwise when they get hot, it'll just come out again and condense on the cold plastic again!
    I found it more reliable to drive the water out once with gentle heat, then make sure all the seals are in place so it can't get back in again.
  1. Mirrors
    By Vectrarmand in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 21:28
  2. Anyone seem these mirrors?
    By ronnie63 in forum Styling
    Last Post: 26th June 2009, 22:17
  3. Mirrors
    By WHOOSH05 in forum Bodywork & Interior
    Last Post: 31st January 2009, 23:31
  4. Mirrors? what mirrors?
    By ALD in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2006, 20:14
