Results 1 to 10 of 20
Thread: cant remove oil filter lid 3.2 still ok to top up oil?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default cant remove oil filter lid 3.2 still ok to top up oil?
    hi all, typical gone to do a job and i get hassle!
    removed the sump plug no problem drained the oil but now the oil filter lid will not budge! aye proper tight! the housing behind started to move ever so slightly. am i likely to break any thing if i go full hog or just best to put new oil in with the current filter? are there any dangers to this aswell?
    any tips?
    Tim
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    it certainly wont hurt putting new oil in tim .....
    Nov 2010
    BRECHIN
    the oil that came out was black
    well overdue! the current oil filter isnt about to turn to mush tho and clog up the engine is it?
    lincolnshire
    what were you trying to undo it with bud ?
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    If it's the same sort of set up as derv v6 with a drain plug on? Just remove the housing but beware that it will be full with oil. That way you no filter is changed to
    Nov 2010
    BRECHIN
    you have the houseing and then there is a screw in cap wich would normally undo. not this time! new oil is in now anyway. will have to do till after the rr meet in falkirk then look into getting it done again just before the winter. cheers guys
    Regular Member Jezzy's Avatar
    S.E
    With an old filter still on the engine, the new oil will get filthy very quickly.
    wirral
    27 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by TimTay View Post
    Sounds like same thing mine stripped threads once I actually got it out
    Nov 2010
    BRECHIN
    as long as i can get a couple o thousand out it i will be happy. just need a couple o months to recoup some of money ive had to fork out this week on the car.
    will have to go into a garage as no way am i stripping threads! would have had a better go at it but wife needs the car in the morning and no way could i risk not having it thru breaking sommit.
    engine sounds smoother already
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    You need to watch what you are doing with the filter housing. I am assuming the Vectras and the Signums are the same. There were locating lugs for my filter housing which I did not know was there before I did my oil change. My filter cover was really tight, and when I tried to take it off the whole housing started to turn with the result that it broke the retaining lugs on the housing. Needless to say small fragments of the aluminium housing were lying around the holes. Fortunately I managed to fish them all out with no damage done. What I am really trying to say is make sure you secure the housing using mole grips or a small set of Stilsons before you try to remove the cover if it is very tight. Either way as someone else said the new oil will get dirty pretty quickly if you don't change the filter. Hope this helps.
    3.2 v6 Signum and loving it
  1. Should I remove cone air filter and what's your highest mileage on a full tank?
    By VikingLammy in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 20:47
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. First Service - Remove K&N Air Filter?
    By Rikkiola in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2006, 16:44
