Results 1 to 10 of 11
Thread: 2004 2.0 dti vecta c not starting.
    uk
    Question 2004 2.0 dti vecta c not starting.
    Help!
    I ran out of fuel last friday on my way to work, luckily in the works car park. I topped up with diesel and used hand primer and bled each fuel line to the injectors while turning the engine over. The car refuses to start, not even a fire from any cylinder.
    I put op-com read codes saved them. Cleared all codes and turned it over and read error codes again. Here are the codes.
    P1565 - <Unknown DTC>
    (72) - Not present
    P0650 - <Unknown DTC>
    (04) - Not present
    C0800 - System Voltage Low Voltage
    (03) - Not present
    C1550 - Replace Electronic Control Unit (ECU)
    (37) - Not present
    U2139 - Invalid Data from CIM (Steering Column Module)
    (7F) - Not present
    B3078 - Anti Theft Warning System Horn Signal Circuit Low Voltage
    (02) - Not present
    B3445 - Rear Left Brake Light Circuit Open
    (04) - Not present
    B2585 - Front Left Parking Lamp Circuit Open
    (04) - Not present
    B1325 - System Voltage Low Voltage
    (03) - Not present
    Any ideas?
    JTG
    East Midlands
    ?Where's the hand primer on the 2.0DTI mate,didn't know it had one.
    Regular Member hendrix's Avatar
    Jun 2011
    Wigan
    maybe worth checking the fuel filter, heard this is a common issue on diesels.
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Have you tried tow starting?
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    more than likely diesel pump very common probs
    uk
    Thanks for the replies. You are correct about the dti not having a primer. I installed one a few years back. I serviced the car 2 months back and a new fuel filter was installed then.
    I have tried towing it to get it started but no joy.
    I was thinking the same about the diesel pump. It's getting diesel up through the injector lines but the pressure isn't great.
    I have a new crank sensor which I will fit to see if that sorts it. Want to make sure it's the pump before I pay for a referb or a new pump.
    Jun 2011
    Elland
    Trawl through the codes and see if there's anything relevent:
    http://www.permoveo.ltd.uk/tabid/122...l/Default.aspx
    maybe more useful for ya http://www.obd-codes.com/faq/obd2-codes-explained.php
    lincolnshire
    Quote Originally Posted by jtg View Post
    someone on the vvoc had his DTi just die and it turned out to be fuel pump but the DTi doesnt have massive fuel pressure anyway bud
    Full Member
    Bristol
    How many miles has the car done. if it done a few first check leak off pipes , if they are ok then it might be injector seals. If you want to check that the pump is working try towing the car to see it will start, if it does then it one of the firts problems.
    uk
    The car has done 146,000 miles. I changed the leak off pipes after it broke down. Also tried towing it to get it going but it didn't start. I will have to take a look at the injection seals. I had been getting a P0400 code for the last year and vauxhall couldn't fix it. Is there a quick method to test the injector seals?
  1. Intermittent starting on my 2004 1.9 CDTI 150
    By burgher in forum Troubleshooting
    Last Post: 30th November 2012, 12:50
  2. want some new alloys for my vecta
    By 0114NIGEL0114 in forum Styling
    Last Post: 7th May 2011, 15:13
  3. starting problems 2004 vectra 1.9 deisel
    By higgy7511 in forum Engine & Drivetrain
    Last Post: 25th October 2010, 00:39
  4. new vecta c owner
    By shaun 37 in forum Introduce yourself.
    Last Post: 10th May 2010, 20:57
  5. Vecta 1.8 Missfire....HELP!!!
    By regjames in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 19:53
vectra c 2.0 dti not starting
