Thread: new cambelt and now a screaming aux belt!
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default new cambelt and now a screaming aux belt!
    just had my cambelt, water pump and tensioners done but started the car this morning and the aux belt was screeching very loud, bit like a banged up old van does first thing in the morning. gave it a few revs and it went away.
    as all the tensioners and the belt are new would this be adjusted up not quite right or will it sort its self out? cheers
    "oops wrong section"
    sorry
    Its self adjusting, but they would have had to remove it to change the cambelt iirc. maybe they have not set it back up correctly?
    Quote Originally Posted by TimTay View Post
    sorry
    did you have the aux tensioner done or just the timing belt tensioner
    as sean said if theyve laid the tensioner on its side they may not have re primed the cylinder on the tensioner and it wont adjust properly
    Nov 2010
    BRECHIN
    had the whole lot done. i know all the pullys and that for the cambelt is new. and the aux belt. not sure it the tensioner is new for that tho.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's possible that with having to take the tensioner to it's full extent to get the old belt off that the spring has weakened (just down to old age).
    Best to just call them and ask for their opinion
    Nov 2010
    BRECHIN
    got to go to forfar in the morning so will pop by and see what the story is. only done it twice and not since. so will see what the morning brings
  1. Replies: 28
    Last Post: 22nd April 2014, 22:56
  2. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  3. screaming noise when i put foot down!!
    By Turbomanrony in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:39
  4. Screaming Baby-Help ! ! !
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 16th September 2008, 17:43
  5. Timing/Cambelt Belt Change On 2.0 DTi
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2006, 08:13
