Results 1 to 10 of 11
Thread: What Do I Need
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default What Do I Need
    Once Again The 206/GTI Forum I Posted This On Is ******* Useless
    Got Clanks/Bangs From Both Front/Rear
    So Heading To Stealers To Buy
    Front A.R.B Bushes
    Rear A.R.B Bushes
    Droplinks X 2
    As I Aint Been Right Under The Car Yet I Dunno The Set-Up...
    Anybody Any Ideas On What Other Bushes/Arms Will Probs Need Changed...
    Then While Doing These Will Check Bearings/Balljoints While I Am At It
    Cheers Peeps
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Might be worth grabbing couple of exhaust rubbers aswel had a few cars where they've stretched a bit and itsvthe exhaust just tapping the body.
    As for your bushes I think your alright on them for now as there's no point changing other things needlessly.
    But it could also be top mounts
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    crikey tam, i hope you bought the pug cheap
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by CritchvxD View Post
    Aint Too Sure To Be Honest Mate...Just Wanted To Grab Few Bits While I Was At The Stealers As Its A Fair Trek From Me...Aint Had The Weather Here So I Can Give It A Right Good Going Over
    Quote Originally Posted by triple595 View Post
    Tell Me Bout It Mate...Its Looking Like I Gonna Have To Go The Whole Road With This And Do Whats Needing Done
    Just Hoping Once I Get It Up In The Air That It Aint As Bad As It Seems...
    Just Cant Hack Driving A Motor With Daft Mental Clanks/Bangs...
    I Looked On Fleabay For Rear A.R.B Bushes...Never Seen Nowt...Take There Must Be A Rear Anti Roll Bar On It ?
    Aug 2010
    Dundee-Motherwell
    ******* Heater Blower/Motor Playing Up As Well...Stop/Start Antics
    Mar 2011
    llandrindod wells
    same resistor pack problems i beleive, seems a common theme on new cars
    Aug 2010
    Dundee-Motherwell
    Works Ok Then Dies (I Say Dies But Can Hear It Going Really Slow/Squealing)...Turn Up The Speed Then It Is Ok For A Wee While...
    Think Its Resistor ?
    If So Any Idea Much We Talking From Stealers ?
    Mar 2011
    llandrindod wells
    it could be overheating then cutting out on the thermal cut out, you wont know till you open it up, might be easier to source a second hand one
    Aug 2010
    Dundee-Motherwell
    Ohhh
    Once I Got The Resistor Out Will/Should It Show Signs Of Overheating ?
    Would This Cause The Motor To Stop/Crawl/Squeal ?
    Mar 2011
    llandrindod wells
    squealing with probably be bearings on the fan motor, or something stuck in there, if you take it out and it sounds ruff, then its ****ed
