Results 1 to 10 of 16
Thread: Regen Signs
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Default Regen Signs
    Hi again all.
    I'm wondering if there are any real signs that the car is doing a regen of the DPF? I heard that the EML light used to flash when it was performing one but was removed by VX after complaints?
    I would really like it if it would let me know when it's performing it!
    Cheers, Dave.
    Jul 2009
    Brighton
    MPG goes down.
    Really bad considering you buy diesels because of the good mpg!
    I also would like to know if there is any definitive sign.
    I think some of the older cars (preface maybe) had the spanner light on during a regen, but so many people took the car into the garage when this happened, so now Vx deleted the warning.
    Jun 2011
    Elland
    Quote Originally Posted by DeeBe View Post
    Hi again all.
    Cheers, Dave.
    Agree it would be good if there was a telltale sign or something that would let you know it's happening.
    Do you have a DPF fitted to your car?? - I'm not sure out of the 1.9s which do and which don't... think it's the facelift estates, autos and signums... not sure about 120 vs. 150 variants.
    Anyway, the easiest way to spot one is the instant fuel consumption will be awful. Idle fuel consumption increases noticeably (my V6 goes from 0.2 to 1.0 gal/h) and you do not get 999mpg on the overrun. Couple this with a different exhaust note (really only noticeable outside the car) and the engine running rough during the process, and it's quite easy to spot.
    Let the process finish: if you interrupt the regen, the car will only attempt to do one next time and bin a load more fuel or if the process is repeatedly interrupted, the DPF will clog and the car will be dragged into a garage on a rope.
    Jul 2009
    Brighton
    Signums and estates have DPF, because of their weight (some euro emission rule or something) and autos.
    I usually notice a regen when my average goes to sub 40s, then look at the instantaneous and that's in the 30s!
    Jan 2010
    wirral
    My DPF indicator is a hole drilled straight through the middle of the filter......when you can't see out of the back window for smoke....you know its doing a regen....simple!!
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    My common signs on my signum 1.9 cdti 150 are slightly rough idle on tick over and fuel consumption goes up from 0.1 to 0.8 on tick over,it does feel a bit rough when its doing its regen and there is a burning smell which you can smell if sitting on tick over,at a junction etc.I always let the process finish and i havent had any problems,the best way to tell when it is finished is when your fuel consumption goes back down to 0.1 on tick over.Hope this helps,steve.
    Jun 2011
    South Shields
    I have a facelift CDTi 120 so it will have a DPF.
    Thanks for the information guys, I'll keep an eye out! I wish there was a way to switch on a bloomin' warning indicator through OpCom or something though!
    Apr 2009
    CO DURHAM
    Facelift 120! Think its only the estates and automatics that have the dpf fitted aswell as the signum.
    Jun 2011
    South Shields
    Really?! Can anyone confirm if mine has a DPF then?!
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Is it a manual? Vectra estate, hatch or Signum?
  1. DPF Regen
    By Andyc6845 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 21:15
  2. what does Regen,,,
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 21:00
  3. DPF & Regen??? WTF!
    By Rab in forum Diesel Engine related
    Last Post: 28th September 2010, 13:05
  4. DPF Regen
    By Avenged in forum Engine & Drivetrain
    Last Post: 20th May 2009, 17:44
  5. DPF Regen
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 28th November 2008, 10:29
