Thread: Heater/Blower Issue... Relay problem with PICS!
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default Heater/Blower Issue... Relay problem with PICS!
    Hi guys,
    What I have done was at my own risk and I'm putting up this thread to express my findings with you guys but also to get some advice.... I'll try and explain this the best I can, and I have also attached some pictures of the relay to give you an idea of what i've done.
    As we all know, there is an known issue with the heater/blowers only working on number 4. Now for some of you, replacing the heater resistor does the trick, but for the majority it doesn't.
    1st of all, I replaced the heater resistor the other week and this didn't do the trick, so left it in. I read up on some threads and some say that it could be an issue with the relay.
    So I got to work and removed the glove box. To the left there were the relays, I removed the Blue relay which is found on the bottom right hand side of the relay box (you can't miss it)
    I took away the cover to have a look at the actual relay to see if I could find anything that looked broken! There was a slight char to the coil so possibly something has burnt out?!
    I read on another thread that when the dial is turned, the relay should 'move' but my relay wasn't moving when switching between 1 - 3. Is this correct?
    After playing about I noticed that there is a mechanism which pushes against the bronze backplate.
    I got a staple, as it was the only thing i could find, trimmed it and bent it so that I could keep this mechanism against the bronze plate. I put this back into the car and right away I could start hearing the motor/fan spinning!
    I turned the dial to 1 through to 3 and it started blowing air! HURRAY..... BUT... The motor/fan is still constantly spinning, as if there is an electrical current always going through it... even with the keys out of the car.
    Now I can only assume that this is a faulty relay as everything else seems to be working fine.
    Can someone clarify this before I go and buy a new relay.
    Regular Member tditony's Avatar
    durham
    Vehicle : 2007 sri xpnav
    Trim : sri xpnav
    Engine : 1.9 150
    yes mate its faulty mine did exactly the same thing got one from the scrappy and its bang on hope this helps
    Jul 2011
    Cheshire
    Quote Originally Posted by tditony View Post
    Hi tditony, trying to add the pictures on, but cool.
    I didn't wanna risk going to a scrappy incase for whatever reason, that one is faulty too lol
    Any ideas how much they would be to buy from Vauxhall Direct? I went to Jim Barkers today and they couldnt locate one
    Jul 2011
    Cheshire
    Here are the pics!
    Jul 2011
    Cheshire
    To confirm, replacing the relay has fixed the problem HURRAY!!!!
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    how much was the relay? I am just about to go through this with one of my cars. I have ordered the resister thing already but may as well get one of those relays, if i don't need it now I am sure i will in the future..
    Jul 2011
    Cheshire
    Quote Originally Posted by Caveman_nige View Post
    I got it for £12.50 from eBay mate, paid for it on Friday and it came today, was made up!
    http://www.ebay.co.uk/itm/Vectra-C-0...#ht_1442wt_907
    I replaced the Heater Resistor... but now come to think of it, I didn't think that was issue all along... but oh well at least I have a new one fitted
    I'm having an issue with my rear wiper not working, so I'm going to replace the relay for that 1st (If I can find out which one and where it is lol) before I start to look at replacing the wiper motor!
    Good luck mate!
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    May i have one in the garage nige, I'll try to dig it out and bring it with me tomorrow
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    cheers guys...
  1. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2015, 21:09
  2. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:47
  3. Heater Blower relay
    By mo-mo in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2010, 13:52
  4. Heater / blower problem
    By lacorbiere in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2010, 14:24
  5. Blower / Heater Fan Problem
    By zealot210 in forum Bodywork & Interior
    Last Post: 11th January 2010, 17:38
