Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: psychological power increses!
  1. #11
    May 2011
    bispham, blackpool
    had the cambelt done on a renault scenic got it back and somehow managed to get even slower than it was at the start didnt think it was possable for it to go any slower but it did needless to say i will not be using the same garage to do the cambelt on my vec
  2. #12
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Probably psychological, but maybe the old water pump and parts were worn enough to affect the performance? May genuinely be running a bit better.
  3. #13
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Will chuck the 1.8 through the car wash, needs all the help it can get!
  4. #14
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    am wondering here, sure someone will put me right if im wrong.
    if a cambelt has been on a car for longer than it should overtime would it not strech slightly? so when a new belt is put on it is everso slightly shorter and allowing more accurate timing with the valves and hence slight power increse?
  5. #15
    Nov 2010
    BRECHIN
    Quote Originally Posted by shadyone View Post
  6. #16
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    reminds me: A "top gear" show a couple of years ago -- they spent about 10 grand on tuning parts for a renault, as an experiment (fitted huge brakes, sport suspension and all sorts) and in the end they found that the modified car was slower around the track than the standard one.
  7. #17
    Cheshire
    Quote Originally Posted by Hideous View Post
    It was seroiusly faster, just not as fast as the scoobie [or was it an EVO] which was the purpose of the excercise.
    Back to the belt change, a lot of **** taking but the timing was highly likely to have been out by a few degrees. We all know from our tuning days a cam can be tweaked a couple of degrees with a vernier to ensure very accurate factory set or enhance the power or torque curves. and with this engine that could be enough to feel!!
  8. #18
    Nov 2010
    BRECHIN
    i like the sound of that
  9. #19
    Cheshire
    Hijack....modified car's do work!! (more than a timing belt change it has to be said)
    just checked:
    The Renault project is 'OUR CAR' as you can see below, it went from the bottom of the board to thrash CTR'S, Elise, Clio V6. some 7 secs better than std.
    Ford Mondeo ST2201.34.5Jaguar XKR1.34.7Ford Focus ST1.34.9Volvo S60R1.35.0Ferrari 575M1.35.2Vauxhall Vectra VXR1.35.3Our Car1.35.4Fiat 500 Abarth1.35.5Alfa 147 GTA1.35.6Lotus Elise1.35.6Aston Martin Vanquish1.36.2Renault Clio V61.36.2Honda Civic Type R1.36.5Alfa Romeo Brera1.36.9Saab 95 Aero1.37.9Maserati 3200 GT1.38.0Alfa Romeo 8C1.38.2Bowler Wildcat1.39.4Bentley Arnarge1.40.8Overfinch Range Rover1.44.0Aston Martin DB51.46.0Hawk HF 30001.48.2
  10. #20
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    Was quicker when they put it on racing tyres & different suspension & took all the seats out, as you'd expect - but the £3grand brakes made it slower
    Best mod = shedding weight!
    http://www.youtube.com/results?searc...+avantime&aq=f
    http://www.youtube.com/watch?v=IiXfuvy3zH8
    http://www.youtube.com/watch?v=mUjFV...eature=related
    The final thoughts on the 3part youtube video sum up their findings
  1. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  2. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  3. Replies: 11
    Last Post: 7th January 2010, 17:50
  4. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
  5. Psychological Test
    By AJA in forum General Chat
    Last Post: 28th April 2006, 11:23
