Thread: Signum ECU failure!
    Nov 2009
    Lancashire
    Eek Signum ECU failure!
    My 2.2Direct Signum is currently sitting at the dealer apparantly with an ECU failure.
    The car died on the motorway with the car&spanner symbol. Turns over but rough and won't start. RAC couldn't fix so towed it. Fault codes for all 4 injectors, throttle sensor and some other stuff I can't remember.
    Dealer says they clear the codes but one remains - ECU Failure.
    £840+ for a new one
    That's alot of money.
    Anybody know of a cheaper repair/replacement option?
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by GrahamS View Post
    I'd ask them to try re-flashing it first...
    and if that fails.. fleabay ..search vectra 2.2 ecu.. eg
    http://www.ebay.co.uk/itm/Vauxhall-Z...item43a88916dd
    then get it 'married' to car... lot less than vx prices
    north east
    check and clean the earth contact on it.
    kingswinford
    Quote Originally Posted by roswell View Post
    as Ros says ... if the ecu supply voltage is low (due to $h1tty connections) it'll throw up allsorts of ecu issues... but i'd expect other faults(sensors etc) to come up first.. but well worth checking.
    Nov 2009
    Lancashire
    Quote Originally Posted by hagga View Post
    Unfortunately ECU's that have not been 'un-married' from the original car when they are removed can not be used on another one.
    I also phoned several ECU repair companies and they all said that the 2.2 ecu can not be repaired. A couple could supply brand new ones but at the £450+ mark and about a week to supply.
    Not looking good
    kingswinford
    Not looking good
    looking around fleabay you find most parts state they've been tech2'd off the original car. I'd try one before shelling out £450+.
  1. Signum auto gear failure
    By Alzay in forum Engine & Drivetrain
    Last Post: 17th July 2012, 20:49
  2. DE CAT MOT failure?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 22:56
  3. Signum rear wiper failure
    By stryker99 in forum Bodywork & Interior
    Last Post: 11th July 2009, 18:42
  4. EGR failure at 25,000
    By StuntDriver in forum Engine & Drivetrain
    Last Post: 18th April 2009, 10:42
  5. MOT Failure
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 19:22
ecu signum wo
ecu signum
