Results 1 to 10 of 11
Thread: Do you have to blank the EGR off if it is mapped out?
    Feb 2011
    Default Do you have to blank the EGR off if it is mapped out?
    If the EGR valve is mapped out does this mean it is closed all the time and therefore a blanking plate is not required? If people do recommend fitting a blanking plate as well...then could you please explain why? Thanks.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    No but, mapping it out will tell the ECU to ignore snesor readings therefore the emissions light won't come on if blanked off. As far as I can make out though if you unplug the EGR valve even if the valve is mapped off of the car, the spanner light will come on. This is due to the fact that the valve is not actually 'deleted', but sensor readings used to determine the EGR valve operation are just ignored by the ECU.
    Feb 2011
    Ok, thanks. That explains how the EGR being mapped out actually works, so that the EGR just sits there and doesn't do anything as there are no readings for it to respond to and therefore remains closed, but I'm still a little unclear as to whether or not I need to blank it off? Or will this make no difference whatsoever? Was your answer 'No - a blanking plate is not required' or 'No -it does not mean what I thought and you do need a blanking plate as well'?
    Sorry for sounding a little dense!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    When I spoke to tuners (chip Tuners being one of them) they said to me you do not need to blank as they map the EGR closed all the time.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mattyc View Post
    Someimes the valve doesn't seal properly too, s oa blanking plate re enforces a properly seal.
    Quote Originally Posted by AntSSSS View Post
    This is true but for a few I have heard the valve is merely ignored but unless a plate is fitted the valve may still allow gases through.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Gazza4 View Post
    Exactly, if you can be certain that your EGR valve is sealed 100% closed, then you don't need to blank it, but can you be 100% sure............
    For the quid that the blanking plate costs, it seems silly not to...
    Regular Member Mads's Avatar
    Ipswich,.UK
    i know a few on here have had remaps and left the EGR in the map, others have had it mapped out, im still deciding whats best but i may leave it in when i get mine mapped has ive never had problems?
    Quote Originally Posted by Mads View Post
    Give it long enough and you will mate, it's design flaw in the engine required by the EU for emissions purposes only - it serves no other useful function...
    Lancashire
    Trim : XP1
    Mileage : 66000
    ....i may leave it in when i get mine mapped has ive never had problems?
    Oh no.... with these, its not if, its when - seriously.
  1. My car mapped today
    By mccluskey119 in forum Petrol Engine related
    Last Post: 28th April 2012, 14:45
  2. Mapped or boxed 3.0 V6
    By Ben Chiles in forum Diesel Engine related
    Last Post: 30th March 2012, 01:20
  3. anyone mapped a 120 cdti??
    By bubba in forum Northern Ireland (RO - Vacant)
    Last Post: 20th January 2012, 01:15
  4. Anyone mapped their own Vectra? Is it possible?
    By Coupe2T in forum Diesel Engine related
    Last Post: 11th September 2011, 17:02
  5. Well, i'm now EDS mapped!! WOW!
    By MCD in forum Diesel Engine related
    Last Post: 14th August 2009, 17:46
if I map out egr still blank it
xan an egr be mapped out without blanking
do you have to blank your egr if it has been mapped out
