Results 1 to 10 of 18
Thread: Number plate lights not working
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Number plate lights not working
    I have my MOT tomorow morning so I went for a quick check around the car.
    The number plates bulbs were not working. So I replaced them with my spare set. Still not working!
    So just got back from halfords and put a new set in. STILL not working!!
    What else can I check is there a fuse?? I Can't see one in the handbook.
    HELP!
    Its a 2005 SRI 1.9CDTI(120) Estate by the way
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Check the connections, see if you have 12v with the bulbs out
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Marky,have you checked the wiring connectors in the back of the light unit,there may be a wire off or connector corroded.check wires for a live supply with a multimeter
    Jul 2009
    Engine : 20 Dti
    sorry triple you answered whilste i was typing! oups
    Jun 2006
    North West
    Its measuring 2.8v DC with the engine running and the headlights on and off.
    Thats measured from the plug that goes into the bulb holder.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Where abouts in the North West are you? You're welcome to poke around mine if you need to double check anything. Something doesn't seem right there though. The voltage should obviously go up with the lights on.
    Feb 2011
    Selby
    Try measuring between the bulb holder and the chassis (find a shiny bolt for example). It could be a poor earth connection.
    If your MOT is imminent, run a wire from one side of the bulbs to chassis, and take an ignition switched 12V from the REC and run that to the other side of the bulbs. Then once it's passed the MOT, investigate further.
    Jun 2006
    North West
    I couldn't find a nice shiney bolt within reach. Bit tricky holding the tailgate and my very short multimeter.
    I did manage to reach the rear towing eye, not the cleanest so I don;t know if thats a good test. Anyway its still only managed 2.9v
    Jun 2006
    North West
    Oh bother... can't find any wire long enough to go from rec to the lights.
    Have to see if I can cancel the MOT tomorow.
    Heres me being efficient and booking online for the cheaper price. Probably loose the money now. grrr...
    Jun 2006
    North West
    Quote Originally Posted by cont1204 View Post
    I'm in Manchester (Home) and Runcorn (Work).
    Thanks for the offer but to be honest I don't fully know what I am looking for comparison
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  3. Number plate lights.
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2010, 22:24
  4. Number plate lights!?
    By byebyeitsagsi in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2008, 13:58
  5. Number Plate Lights
    By Stringlabel in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2005, 13:17
