Results 1 to 10 of 21
Thread: Driver Door showing as 'Open'
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default Driver Door showing as 'Open'
    Hi guys,
    I'm having a problem with the drivers door. When I close it, it still thinks the door is 'open', therefor when I come to lock the car, it'll unlock right away.
    I have to give it some force a few times to shut the door to allow it to recognise that the door is 'closed' then it'll allow me to lock.
    Most of the time its fine and can open and close it properly all day and lock it without any problems but the odd occasion it'll think its 'open'
    Can anyone make any suggestions on possible fixes that I could do myself... bare in mind i'm a complete novice, but willing to give anything a go rather than having to take it to the garage for it to be looked at and get charged through the roof!
    Has anyone else had this problem, and what was the fix for them?
    Lew
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Alter the catch plate mate. Try moving it inwards a mm at a time until your sorted. There should be mm increments marked on it if I remember correctly.
    Regular Member Innes's Avatar
    Plymouth
    It sounds like the motor in the lock is about to fail. A fairly common problem. Enough to have a HOW2 written about it. I had to do this on my vectra and it's a real sod!
    To help with the central locking situation THIS should help.
    Jul 2011
    Cheshire
    Hi Rushy, thanks for your advice. What and where is the catch plate? Is it fairly easy to get to and adjust?
    Quote Originally Posted by Innes View Post
    Hi Innes, cheers for letting me know, something else I can look into but those links didn't work, sent me to the main forum :-(
    Lew
    Vehicle : SRi
    Mileage : 137000
    Its the bit on the bottom of the C pillor that the door catch locks on to.
    Plymouth
    Try this.
    Replacing Door locks:
    http://www.vectra-c.com/forum/showthread.php?t=77009
    How2 lock the car when locks fail:
    http://www.vectra-c.com/forum/showthread.php?t=107466
    I'd you still can't see the links go to the how2 section of the forum and click in the index thread. You'll find them in there.
    Jul 2011
    Cheshire
    Hi Rushy,
    I'm failing to see where this is... do you have any pics to give me an idea what I'm looking at all?
    If it's the drivers door, I can't see it being anything to do with the c pillar.
    Vehicle : SRi
    Mileage : 137000
    B pillar
    Quote Originally Posted by lew1984 View Post
    Hi Rushy,
    This a google image of a vec b catch plate, but you'll catch my drift.....
    Plymouth
    To be honest it doesn't sound like the catch plate. If it was then the door wouldn't actually shut properly. Seeing as the door does shut properly then it sounds Like the electronics in the door lock are fooked. A new lock is about £78 from the dealers. I wouldnt get a 2nd hand one as the same thing could happen further down the line.
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. Replies: 9
    Last Post: 15th October 2010, 17:57
  4. One free ticket for Scottish Modified tomorrow! (for car and driver showing)
    By John LE in forum East Scotland (RO - signumboy)
    Last Post: 17th July 2010, 23:33
  5. Driver side door shut but showing open on display
    By eclipse in forum Bodywork & Interior
    Last Post: 13th August 2008, 11:14
