Thread: Anyone explain this 1.9 CDTi 150
    Sodding Typical on Sea
    Default Anyone explain this 1.9 CDTi 150
    I am on my second car with this engine, neither sounded alike in any case, this one is a lot more gruff sounding than the first, a lot less smoky, and a little less economical.
    BUT,,, I recently performed the EGR restricted gasket mod, the small one with three hole not the larger rectangular one.
    I have noticed my engine sound quite a bit different. It has a more deep and hollow note to it, much nicer than it was before. I cannot put it down to anything else as all I did was remove a very minor amount of carbon from the egr check the operation, then add the lower gasket.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Have you check the air filter, and of the airbox mod has been done?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The only thing I can think of is the gasket is causing slightly higher pressure drop across the two manifold - ie exhaust is finding it easier to pass through the turbo and out the exhaust. Also there is easier flow of gases through the valve. It's a bit feeble as theory tbh.
    That gasket isn't the one I gave you in March is it?
    Insignia VX-Line Nav CDTI 170.
    Quote Originally Posted by Gazza4 View Post
    It is mate, and it is quite a noticeably nicer engine tone.
    Ian, the Airbox mod was done on October 18th last year (the day I collected the car) the Air filter was new in Feb also, so this has really been the only mod.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Ok, just mulling it over, wondering what could be contributing to it. Some engines do sound and run sweeter than others, but what you are describing is more than just a sweet engine. Gazza4's theory sounds as good as any.
    Regular Member coooky's Avatar
    May 2011
    washington
    along as its running fine why worry about the sound lol
    maybe you last one was a bag of hammers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Maybe the EGR feeder pipe was loose before, and now you have removed the bolts and refitted them (to fit the gasket) its now as tight as it should be??
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Just changing the boost level or fueling can change the tone on the exhaust, so it's nothing to worry about if the noise is the only thing that has changed.
    Thanks guys,
    Not worried about it much prefer it to be honest, the change is subtle but different. I was wondering if it was the restriction in flow from the new gasket and am concluding it is.
  1. some 1 please explain
    By nath-lav in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2013, 21:21
  2. please explain
    By neill in forum General Chat
    Last Post: 12th January 2012, 00:25
  3. Can someone please explain ?
    By john1 in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 09:48
  4. car tax ? can anyone explain ?
    By STAV in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 19:30
  5. Can someone please explain.....
    By parapaul in forum Detailing and Car Care Discussion
    Last Post: 28th May 2007, 21:34
